New PCX top speed???
- sendler2112
 - Year: 2013 PCX150
Re: New PCX top speed???
The speed reduction is perfectly cyclic and uniform in frequency and amplitude. It never happens at 67 mph. It always happens at exactly 68 whether down hill or on the flat. I have experienced the eery feeling of hp balanced against the wind during top speed testing on my CBR250R. There is no cyclic surging. Only a random and natural interplay between the power and the wind. What I see happening with the PCX is definitely not like that. Too bad Honda didn't put a menu selection into the the screen to change the mileage into an occasional tach read out. Then we would know if I am at redline or not.
				edscoot
With 13,000 miles on the clock I don't get higher than 56-57mph top speed indicated (not gps, so probably slower - lorries overtake me now). This could be down to the belt getting near it's replacement at the 15k service.
Similar with mine, at 11000 miles its only doing 61mph indicated.
When new it did 67mph indicated.
Pop a new belt and rollers in and I'll bet it'll be good as newedscoot wrote:With 13,000 miles on the clock I don't get higher than 56-57mph top speed indicated (not gps, so probably slower - lorries overtake me now). This could be down to the belt getting near it's replacement at the 15k service.
The reason I think the ECU limits by speed is, it goes the same top speed on the centerstand at max throttle as it does under load.
It's entirely possible it's limited by RPM or another measure though -- I'm by no means a Honda engineer, just a backyard mechanic speculating.
My PCX has the same symptoms as gn2 and edscoot too, my top speed is down from 61 to 59mph. Something else must be coming into play here...
Currently ride:  Nothing right now - mostly mountain biking with my boys until they're old enough to ride
One wonders where the ECU and speedo get their information from...?
gn2 wrote:One wonders where the ECU and speedo get their information from...?
The Dail Mail
Or the Daily (hate)Mail
I remember a study which concluded that reading The Wail on a regular basis was likely to induce stress and/or depression.
Not the paper for me, I used to read The P&J.
That Dail Mash is class. Ive already forwarded the NHS story
There's some real crackers in it, the Agony Aunt column is usually hilarious.
				TasmanianDevil
My top speed is 76mph about 122kmh.maddiedog wrote:The reason I think the ECU limits by speed is, it goes the same top speed on the centerstand at max throttle as it does under load.
All the pcx i know do more than 100kmh...
				TasmanianDevil
Blasphemy!! You are going to start up the wrath of middle age dark times christianity priest who may burn you on the stake for claiming such things...Dont bother with which-craft video proof , thats just as bad and will not change their small mind ignorance thinking way. You will still buuuuurn...TasmanianDevil wrote:My top speed is 76mph about 122kmh.maddiedog wrote:The reason I think the ECU limits by speed is, it goes the same top speed on the centerstand at max throttle as it does under load.
But on the other subject,what have you done to yours to get it up there?
Cheers
Tasmanian devil where are you located? I get 106kmh indicated on my original 125.
				TasmanianDevil
I'm on Portugal.Taz wrote:Tasmanian devil where are you located? I get 106kmh indicated on my original 125.
Once i reached 124kmh but it is hard to do.
I will make a vídeo for you. In Portugal there are many doing 75mph.
You mean like a video where the speedo indicates 118kph which is proof of being able to do 127kph...?Pcxdemon wrote:which-craft video proof
				Cooley_PCX_Rider
Wheel bearings.......brakes.........tire size............
Many things on a scooter are not designed to run over a specified speed. You can hot rod anything you like
but perhaps your personal pilot should take this baby out on the roads and test it for you should your math
be off a bit.
LOL
be off a bit.
LOL
PCX 150 Rider from East Central Illinois in the middle of the United States of America
- sendler2112
 - Year: 2013 PCX150
Your speedo reads fast by 8%. Maybe 10%. What is the year and displacement of your PCX?TasmanianDevil wrote:My top speed is 76mph about 122kmh.
