Parts missing
Frantisek
Color: Bloody RED
Parts missing
Post by Frantisek »
Hello i crashed the motorcycle this month. Got video here https://m.youtube.com/watch?v=C13Rcj_GeZY
Of parts missing or broken. Do you have estimate what it is going to cost from asia?
Frantisek
Color: Bloody RED
Re: Parts missing
Post by Frantisek »
I was able to find out what parts I am missing but maybe someone has a good bundle idea where to get all items for a good price :)
Re: Parts missing
The headlight assembly alone costs quite a bit - guessing it will be best part of £400+ for parts.
Oyabun
Year: `12,`15,`19
Color: black&black
Re: Parts missing
Post by Oyabun »
Frankly, I cannot really get from the video what shoukd be replaced. The resolution is quite low as well as you move too quick.
You apparently need a front fender and a headlight, as well as a windscreen and instrument cover.
Most probably the tabs on the side covers are missing - but cannot get it from the video.
If you're lucky the headlight stay and the instrument panel are intact. Other than that can be only known if the bike is dismantled.
As I wrote earlier a full fairing set from Thailand runs around 400EUR including shipping and customs - but the colors are different. Plus it does not contain non-painted parts should you need them.
I have a color matching unscratched front fender and a scratched right side part which have no cracks and has all tabs intact.
Frantisek
Color: Bloody RED
Re: Parts missing
Post by Frantisek »
Oyabun, yep I count with you too. Here is HD video, 360p
https://www.youtube.com/watch?v=-ddxqU-v8eA
Oyabun
Year: `12,`15,`19
Color: black&black
Re: Parts missing
Post by Oyabun »
Seems that in the workshop they have removed the panels to assess the damage, and just haphazadly put everything together.
As far as I know there are parts missing from the bike:
- headlight unit
- meter panel cover PANEL, FR. METER *NH1* (BLACK) 64336-K35-V00ZA
- windshield
- inner covers
- Grill (GRILL, FR. 64305-K35-V00)
I'm not sure from the video if tabs are missing from here or there, but I think some of your side panels have lost a teeth or too in the fight with the car, and also cannot figure out if the headlight stay is straight or not (probably not, as your front end looks a bit odd spaced, but I might be wrong).
Also would check the steering stem bearings as they are notorious to fail on the PCX. They cost around 10 EUR for a set, and easy to change if the bike is apart, but a major PITA if you find out after assembly.
Have you received any report, or list with the quotation from the repair shop what should be changed?
Very important! I don't see the LED driver circuit on the picture. it is vital to run the headlight and cost some healthy money also, so you want to make sure that you get it back from the shop done the first assessment.
edit: I have revisited the after crash picture you have posted in your original topic to see the damage in situ. It seems to be highly unlikely that the headlight stay has survived intact- get it checked. also make sure that you collect and preserve the small yellow plastic clips (CLIP, SNAP FITTING, oem part number 90601-SJA-003) which are used to snap fit some parts of the front as well as all screws and misc parts as they run 1-2EUR each and add up to some healthy sum.
Oyabun
Year: `12,`15,`19
Color: black&black
Re: Parts missing
Post by Oyabun »
In case you don't have a list of parts to look for from the service offer, I suggest to carefully remove all panels, line them up and check for cracks and missing tabs and pieces.
Respraying color damage is easy, replacing missing pieces is not. Once established what you need you can start to look around online sources and brokers - but I've found that even though second hand parts can be reasonably cheap, delivery costs can be killer sometimes.
Frantisek
Color: Bloody RED
Re: Parts missing
Post by Frantisek »
I have some high quality pictures now.
http://imgur.com/a/d7Bry
+ I got the original windshield.
d.a.rous
Year: 2014 JF57(125)
Color: Carbonium Grey
Re: Parts missing
Post by d.a.rous »
Frantisek wrote:Hello i crashed the motorcycle this month. Got video here https://m.youtube.com/watch?v=C13Rcj_GeZY
I can recommend you the Vancho very, very cheap prices, original Honda parts from Thailand, within 10 days, I got the desired parts of it.
YSS G-Euro XL Red shock
Dr Pulley SR2015 13g sliders
Dr.Pulley SP2015-AK sliding pieces
SH Clutch (Facilitated)
Malossi Clutch Spring (Red)
High beam Passing (Flash)
Low beam switch (on/off)
Oxford HG "Touring"
Drive Belt Cover + Swingarm (Matt Black)
Michelin City Grip
Vancho
Year: 2012
Re: Parts missing
Post by Vancho »
I can send it from Thailand. Contact me if interested
Frantisek
Color: Bloody RED
Re: Parts missing
Post by Frantisek »
Vancho wrote:I can send it from Thailand. Contact me if interested
Hi,
What It? A bit more communication would help. Can you name the parts and tell me the price here? It would help to the transparency, I can see you have a review here already but the user joined just month ago so it still doesn't prove anything ;-)
I was thinking about bikersbitz, what is difference between you and them?
Oyabun wrote:In case you don't have a list of parts to look for from the service offer, I suggest to carefully remove all panels, line them up and check for cracks and missing tabs and pieces.
Hey, I dont have all the parts, they were smashed or left by the road after the accident. There are some in the seat as I recall, I'll have to take pictures of what's left one more time.
Vancho
Year: 2012
Re: Parts missing
Post by Vancho »
Hi,
Ok
Tell me details about your crash. How it done? Which points of the scooter it got the knocks?
Could you give me your VIN and color code for confirm part number of spare parts your scooter needs for replace?
Vancho
Year: 2012
Re: Parts missing
Post by Vancho »
here is the broсhure about body parts
It can help to understand which parts you need
PCX150G R-263.jpg (338.56 KiB) Viewed 8863 times
d.a.rous
Re: Parts missing
Post by d.a.rous »
@ Frantisek
You need:
33100-K35-V01 Headlight
64504-K35-V00 Light Cover Below
64305-K35-V00ZG Sheet Sets Off The Front Car
64501-K36-T00ZA Light Cover On The Right Car (Fastening broken) http://i.imgur.com/EG67BfW.jpg
64503-K35-V00ZG Cover The Front Of The Car
81139-K35-V00ZG Cover The Outside Of The Glove Compartment Of A Car Left
81138-K35-V00ZG The Outer Cover Of The Storage Compartment In The Car
64432-K35-V00ZG The Cover On The Left Side Of The Car
Which Color you have R320,R350 or R263?
Oxford HG "Touring"
Michelin City Grip
Frantisek
Color: Bloody RED
Re: Parts missing
Post by Frantisek »
Vancho wrote:
Hi,
Ok
I was driving about 40kmh, when car in front of me suddenly stopped, I hit the car in front of me in about 15-20kmh into his rear bumper, I hit only by my front wheel and headlight, then the scooter fell on its side. The hit was direct. I flew to left on the road.
I can have VIN in several hours. Will reply soon.
d.a.rous wrote:@ Frantisek
You need:
Where do I find the color code? I think I need right mirror, too.
d.a.rous
Re: Parts missing
Post by d.a.rous »
Frantisek wrote: Where do I find the color code?
In the helmet compartment (Storage Box)
Oxford HG "Touring"
Michelin City Grip
Vancho
Year: 2012
Re: Parts missing
Post by Vancho »
This is the part list I was only manage to note from your video and photos:
1. 33100-K35-V01 Headlight
2. 81138-K35-V30 OUTER, R. INNER COVER
3. 81137-K35-V30 Cover
4. 81139-K35-V00 OUTER, L. INNER COVER
5. 64432-K35-V00 COVER, L. SIDE
6. 50530-K35-V00 Side stand
7. 88210-KWN-900 Mirror Right
8. 88114-KWN-900 Boot Mirror
9. 88115-KWN-900 Cap lock nut
10. 90301-KWW-640 Lock nut
11. 90103-KZR-701 Bolt adapter
12. 61100-K35-V00 Front Fender
13. 50310-K35-V00 Stay Headlight comp
I'm not sure, but may be also need to replace:
1. 51400-KZY-741 Fork Right comp
2. 51500-KZY-741 Fork Left comp
3. 44650-K35-V00 Front Wheel Disk Comp
4. 45351-KVG-901 Front Brake disk
5. 53100-KWN-710 Handle bar
and smth more, coz it's quite difficult to diagnostic by only photo and video. I also don't excluded some kind of hidden damages.
Frantisek
Color: Bloody RED
Re: Parts missing
Post by Frantisek »
Vancho wrote:This is the part list I was only manage to note from your video and photos:
The scooter is functional, rideable. It also breaks. so the other parts are not necessary. What is your price estimate for this including delivery to Slovakia, Zilina?
Vancho
Year: 2012
Re: Parts missing
Post by Vancho »
So, only first list, right (13pos)?
Parts will 9435THB
+postage (for your choose):
Parcel surface. 2005THB
or
Parcel Air. 4735THB
Vancho
Year: 2012
Re: Parts missing
Post by Vancho »
Also I noticed but forgot include to the first list
- it two large sides panels L/R. They damaged in front of it- uder headlight point:
64501-K36
64502-K36
