New PCX 1 Month use review
Medicpcx
Color: Grey
Post by Medicpcx »
So a month ago I got the New PCX with ABS so decided to review the first month.
In the month I have done around 400 miles on a variety of roads including motorways.
The lowest MPG with I have had is 123 after 20 miles of motorway driving, The best MPG was 129.3 on every day riding on a variety of roads from 20-50 miles per hour. The average has been 128-129. (All with Idling Stop activated.
Handling is very good and responsive with it being able to easily weave through traffic.
Lights are a lot better with massive improvements to the rear lights.
Digital speedometer is very clear to read and responds very quickly to changes. The speedometer is able to show Miles and Kilometers per hours and can be easily changed between the two.
The clock is also now easier to change with it going up in hours intervals rather than 10 minutes as before.
Max speed displayed was 73mph what is around 65mph in real life. As with all vehicles there is a difference of around 5-10% between displayed and actual.
Breaking is a lot better than previous models especially with emergency stop. Breaking is a lot smoother but is quicker. Yet to test on wet road surface but can already tell it will be a lot better.
Under seat Storage is larger, depending on helmet may fit under seat but uses mine for equipment.
Glovebox is slightly larger able to possibly hold a few small items, height wise. Still has 12v socket but does need to be open to use.
Servicing period changed. 1st service still at 600 but then at 4000 instead of 2500.
Any additional questions add bellow and I will try and answer them.
Pictures to follow some time soon.
cnikonpete
Re: New PCX 1 Month use review
Post by cnikonpete »
Thanks Medicpcx
great information,I am hoping to get mine in a couple of weeks,what are you doing for security? I'm thinking of disc lock,but others suggest chain etc.
I think I will get the dealers to do 600 ml service,then see if I am happy to do 4,000 ml service myself,although it will be 12 months as I won't be doing any where near that mileage.
Really pleased that you are enjoying your PCX so much,making me confident of my purchase.
All the best and thanks again
springer1
Post by springer1 »
I’m thinking the scooter magazine reviews I’ve read indicated kudos to previous years PCX speedometers being very close to actual GPS. Interesting this model is that far off. 8 mph high at 65 is @12% off.
erisaman
Year: 2015/Forza 300
Post by erisaman »
Thank you for that review - the first I've read from an UK owner.
And yes, special thanks for the mention of ...."The speedometer is able to show Miles and Kilometers per hours and can be easily changed between the two." I appreciated that ;) .
If you don't stand for something - you'll fall for anything.
big bear
Color: silver
Post by big bear »
ive had mine for a little over a week now ive ridden 110 miles so far i love it. Its real easy to handle which for me is important im 63 and i have arthritis
Medicpcx
Color: Grey
Post by Medicpcx »
cnikonpete wrote:what are you doing for security? I'm thinking of disc lock,but others suggest chain etc.
All depends on the situation for me.
I got Datatag fitted as with all the bikes I have owned.
The minimum I use for example a quick stop to run into a shop, when in the garage, in secure parking at work I use an ABUS insurance lock through one of the spokes, not that good but gives a quick method if only leaving for a few minutes or somewhere secure.
The next level I use is the ABUS and an Oxford Boss with an Krytonight cable between the lock on the wheel through the centre and side stand.
Third level I use is the ABUS, Oxford Boss, Cable and Chain what will be to something solid.
To me the security all depends on the situation and where I am.
Where possible try and park somewhere busy where a lot of people will be passing and lock up around and see if CCTV is about as that is two things theifs hate.
Medicpcx
Color: Grey
Post by Medicpcx »
I is roughly what it actually is as I could be 2-3mph off as it was only at the top speed for a few seconds. The reason they are saying it is closer is as you are given an actual number rather than trying to guess where it is as with a classic speedo is that the speed can be different depending on the angle you look at.
Parallax error it's called.
Mind you back in the day some speedo needles could vibrate so much working out your speed to the nearest 10 to 20 mph could be an issue :lol:
I don't know if you have the model that has the different size tires from previous models but if so they could cause an error in your speedometer.
My 2013 PCX 150 model speedometer is off about 10% until I reach 45 mph. Then the error starts dropping and is right on the money at 75 mph now (GPS checked). At 67 mph indicated, GPS said that it was really doing 64 mph.
Medicpcx
Color: Grey
Post by Medicpcx »
I am just going by roughly what I have noticed. It is one if the new models with slightly larger wheels. But will do some more advanced testing during the summer.
Medicpcx
Color: Grey
Post by Medicpcx »
So after some testing I can confirm on my PCX speed displayed to actual speed is as follows.
21mph displayed = 20mph actual
32mph displayed = 30mph actual
43mph displayed = 40mph actual
54mph displayed = 50mph actual
64mph displayed = 60mph actual
This data is from test using the displayed speed to a GPS speedometer with the speed being maintained for at least 1 minute with it being repeated twice.
Medicpcx
Color: Grey
Post by Medicpcx »
Disclamer: The above figures are from personal experience and should not be used as official data. A number of things can change the gap between displayed and actual speed. Please remember it is a speed limit not a speed target.
Medicpcx wrote:Disclamer: The above figures are from personal experience and should not be used as official data. A number of things can change the gap between displayed and actual speed. Please remember it is a speed limit not a speed target.
Numbers posted in my Ohio burg are the.minimums, apparently. Wise drivers add 15 to 20% more, to lessen gun play.
springer1
Post by springer1 »
Medicpcx wrote:So after some testing I can confirm on my PCX speed displayed to actual speed is as follows.
Thanks for making the effort to compile this !
JustPassinThru
Post by JustPassinThru »
Mel46 wrote:I don't know if you have the model that has the different size tires from previous models but if so they could cause an error in your speedometer.
Uh...how do you get it up to 75?
My new-to-me 150 tops out at 65. And that's with a tailwind.
I love it! and want one.... sooooooo I need to sell my 2015
bye, bye precious hello PRECIOUS the 2nd
Medicpcx
Color: Grey
Post by Medicpcx »
It was on a motorway with a bit of a down wards hill and was pretty tucked in and low to get little wind resistant.
djbass
Year: PCX150, 2015
Post by djbass »
Medicpcx, add photos, interesting to see. PCX 2018 has an excellent dashboard and looks very modern, it is a pity that it can not be placed in the previous generation 2014-2017.
Medicpcx
Color: Grey
Post by Medicpcx »
djbass wrote:Medicpcx, add photos, interesting to see. PCX 2018 has an excellent dashboard and looks very modern, it is a pity that it can not be placed in the previous generation 2014-2017.
Planning to add photos soon
Medicpcx
Color: Grey
Post by Medicpcx »
Pictures now added in new post in General Section of Honda PCX.
