It happened twice.
Wait a while, start the engine, I can feel difficulty in starting as usually start right way, but takes 3 cycles of ignition to start.
The cause? thank you.
Idling 20s, slight throttle, engine stopped.
- Color: WHITE
Re: Idling 20s, slight throttle, engine stopped.
I believe spark plug, valve clearances and fuel are usualy suspects.
- d1ckyh
- Year: 2018
- Color: Blue
From past experience, an air leak can cause higher than normal idling and may contribute to starting issues.
PCX - Peace Comes with eXcellence
- Color: WHITE
thank you, gents above.
