OBD port?
Posted: Mon Aug 28, 2017 4:32 pm
by pappasmurf
My 2017 125cc PCX needed an oil change.
This was done, yet there is still the message 'Oil Change' on the dash.
How is this cleared?
Is there a procedure?
Is there an OBD tool or similar available for the PCX?
I've seen many OBD tools online, but not sure which one works on the PCX.
Also read somewhere that the PCX doesn't have an OBD port.
Can anyone clarify?
Thanks.
Re: OBD port?
Posted: Mon Aug 28, 2017 6:40 pm
by homie
Not 100 percent certain because I don't have this feature but I seen it on youtube with another Honda scooter.
Warning to all the rest of us without the new oil change light... don't do this :roll: It will disable the limiter and you will go 100 mph.
With ignition off push & hold the clock button.
turn on the ignition, release button.
Re: OBD port?
Posted: Mon Aug 28, 2017 6:52 pm
by homie
Oh and let us know if this works so admin can change the title to something searchable... thanks
Re: OBD port?
Posted: Mon Aug 28, 2017 7:40 pm
by TheMaverick
homie wrote:Not 100 percent certain because I don't have this feature but I seen it on youtube with another Honda scooter.
I don't have a clock on mine, so I held down the trip reset button instead, but only get 95 MPH :(
#SoDisappointed!
Re: OBD port?
Posted: Tue Aug 29, 2017 1:52 am
You are right, no obd port which is a shame.
Re: OBD port?
Posted: Tue Aug 29, 2017 9:35 am
by easyrider
Re: OBD port?
Posted: Tue Aug 29, 2017 10:01 am
by izani
Do google for HiDS (Honda Injection Diagnostic System) by Starnics, from Indonesia. Used by Honda dealer there.
Re: OBD port?
Posted: Tue Aug 29, 2017 10:18 am
But they arent ECU reader ports...?
Re: OBD port?
Posted: Tue Aug 29, 2017 10:47 am
by easyrider
Oops..my mistake...OBD port could be a bit more challenging but not impossible..I don't know why I was thinking USB ???
Re: OBD port?
Posted: Tue Aug 29, 2017 7:28 pm
by pappasmurf
Just tried that.
Didn't do anything.
Still says 'Oil Change'.
Re: OBD port?
Posted: Tue Aug 29, 2017 9:16 pm
by homie
Just tried that.
Didn't do anything.
OK try this one, with ignition off press and HOLD RESET button while turning the ignition switch to the ON position, and keep holding the RESET button for more than 3 seconds. This is how the Forza owners do it maybe it's the same procedure on the new PCX.
