I would like to run a tack, Who is using one, do you like it, where can I get a good one but not high $ and
one that is easy to hookup.
Please let me know.
Tachometer
- ItBeMe
- Color: Very dark blue
Tachometer
Re: Tachometer
Koso is nice, no mount kit comes with it so you can fix it anyway you like. Recommend strapping to the bars somewhere with velcro or bands. All you do is wrap the lead around the sparkplug wire several times. I has the ability to show RPM for single or multiple cylinders, comes set up for twin so you must change its default setting. The instructions are in broken english but you can read between the lines. You will need to remove the lower panel to route the wire with any tachometer.
Fix it to the bars, run the leed down the column with the rest of the cables. Guide it along the undercarriage to the sparkplug and wrap it around the wire 10-15 times. Done!
https://www.amazon.com/Koso-BA003040-Mi ... tachometer
Now they have a stainless bracket for it I may have to order that since I don't use my rearview mirror mounting locations it would bolt there nicely. But check to see if there is anywhere else to bolt the bracket before you buy it.
https://www.amazon.com/Koso-BE006S00-Br ... QS6F3Y8458
- unnamed.jpg (80.45 KiB) Viewed 2652 times
- WI_Hedgehog
- Powered by angry squirrels
- Color: PearlDrkAshBlue
Re: Tachometer
I just ordered off eBay for $12:
DC 12V Mini Auto Parts 2 inch 52mm Tacho Tachometer RPM Pointer Gauge Blue LED
https://www.ebay.com/itm/DC-12V-Mini-Au ... 2749.l2649
It's blue, and I like analog better than digital (faster to read when RPMs are bouncing). I'll let you know how it goes.
Re: Tachometer
Iv'e had good service from this one for a couple years for those who like digital. There is a mount that was recently offered for it (see frequently bought together)WI_Hedgehog wrote:I just ordered off eBay for $12: It's blue, and I like analog better than digital (faster to read when RPMs are bouncing). I'll let you know how it goes.
https://www.amazon.com/Koso-BA003040-Mi ... Tachometer
Re: Tachometer
It doesn't appear to be for a single cylinder? Four, six or eight.WI_Hedgehog wrote:I just ordered off eBay for $12:
- WI_Hedgehog
Re: Tachometer
Correct, that might be an issue, for the price the gamble seemed worth it.
These only take a pulse off one plug, and that one plug only gets one pulse per revolution, so RPM should be triggered the same regardless of the number of cylinders. From recall my digital strobe light has a switch for the RPM readout, so there may be an issue--i'll check it against the digital tach.
It hasn't arrived, when it does I'll update the forum.
Re: Tachometer
I hope it's okay to post in an old thread.
I'm thinking of getting this one from China... https://www.aliexpress.com/item/32421385314.html
Any thoughts?
Any thoughts?
Re: Tachometer
I cant stand not having a Tach on my bikes. Mandatory to tune the CVT properly for performance.
TTO tach. Highly recommend.
2017 PCX 150
Wirus Win Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Wirus Win Exhaust
Z-Bars
NCY Variator
