Honda PCX 2013 - Changing LED Headlight
Cyruscmh
Post by Cyruscmh »
I would like to change the headlight to LED.
But I have a question on the DC / AC...
I am going to replace the headlight to this LED light. Is it I additional need a AC/DC converter?
Thanks a lot!
easyrider
Color: blk
Re: Honda PCX 2013 - Changing LED Headlight
Post by easyrider »
I did not use a converter.
Cyruscmh
Post by Cyruscmh »
easyrider wrote:I did not use a converter.
so does it means that after removing the original headlight bulb, i just need to connect the 3 pins of the LED directly to the original socket like below photo, then it's OK?
lolofigo
Year: 2012
Post by lolofigo »
I have done exactly that. Changed round connectors to flat ones and they fit original socket so I can switch back to halogen lights if needed.
grndslm
Post by grndslm »
Hmm.... Didn't realize this would be so easy. :)
What's the part number for the LED bulb? And where to buy?
Cyruscmh
Post by Cyruscmh »
grndslm wrote:Hmm.... Didn't realize this would be so easy. :)
i just finished changing to LED, and yes it's quite easy...
i bought it from Amazon JP
ScottDR
Post by ScottDR »
I also did the switch about a year ago and used the Posi-tap connectors. It's an HS5 bulb but currently not on ebay where I found mine. Hmmm. Hope you can find a decent price somewhere. Remember you need two.
2013 Black PCX 150
Mods/accessories:
Previously owned:
1975 Honda CB125
1986 Kawasaki Ninja 250r
ScottDR
Post by ScottDR »
Oh, and Cyruscmh, please add your location information. It can really help especially if someone else is a PCX guru in your area :)
2013 Black PCX 150
Mods/accessories:
Previously owned:
1975 Honda CB125
Cyruscmh
Post by Cyruscmh »
OK, done :lol:
