Yamalube Spray Polish.... good enough for rust proofing PCX?
grndslm
Post by grndslm »
Guy at the dealership today told me that Yamalube Spray Polish is the best ever. It'll keep the chrome rust free, *and* it'll clean the plastic, mirrors, windshield, painted metal, etc.
This stuff will do it all, apparently. I'd like to wipe the whole bike down tonight before it's supposed to rain tomorrow. This isn't a bad idea, is it?
Re: Yamalube Spray Polish.... good enough for rust proofing
Don't know, had to go see what it was designed for....
I've been testing this stuff the last few wipe downs http://www.ebay.com/itm/281617774810?_t ... EBIDX%3AIT
easyrider
Color: blk
Post by easyrider »
Made by Simonize..??
grndslm
Post by grndslm »
If I didn't know any better, I'd say this stuff is repackaged wd-40.
Nah.... I know it's a little bit different, but not a lot??
Year: 18 300 xmax
Put on a true Si02 coating....the real deal......
http://www.autogeek.net/cquartz-reload-spray.html
‘15 PCX build thread here:
PCX150Rider
Post by PCX150Rider »
Changed out the gear oil with 85W-140 weight Wolf's Head in my Roughhouse today. . .90ml. . .used a 10ml syringe 9 times. Couldn't see any grit in the drained oil. Always seems like less comes out than I put in. Optical illusion I think. :roll:
Anyhow. . .after that I used S100 spray cleaner to wash the winter grime and residue off. Did a nice job. Can't let it dry though or bake in the sun. Have to work fast with the stuff and use the jet setting on a hose for more pressure. Avoid electrical or sensitive areas. :geek:
Here's the story https://www.youtube.com/watch?v=qrvVbgsaFlk
I just have used the regular cleaner that you spray on and hose off. Good for a quick job but if you really want to spend the time to detail then you'll have to put off the ride for a little longer. 8)
