I see YSS Z Series, YSS G Series and a few others in between. What is the general consensus on rear shocks for these chariots?
Also where to snare a good deal?
Cheers
Rear Shock Upgrade PCX150 LED model
- MayHem
- Year: 2012
2012 PCX150 - Red Sold
2015 PCX150 - White
2015 PCX150 - Red
2015 PCX150 - White
2015 PCX150 - Red
- Year: 18 300 xmax
Re: Rear Shock Upgrade PCX150 LED model
The Z series work very well and are pretty cheap. I've had them on my bike now for 18 months and they still work very, very well, especially over speedbump's in my neighborhood at speed.
‘15 PCX build thread here:
- MayHem
- Year: 2012
Ok well a bit more info, I'm 88kg (195lb) and ride on my own mostly but when 2 up with the wife they struggle, she is 66kg (145lb). Do you think the XL would be the choice? Also where did you buy yours from? Can only see bikerbitz (cheapest of the two) and powerbypcx
Cheers
Cheers
2015 PCX150 - White
2015 PCX150 - Red
2015 PCX150 - White
2015 PCX150 - Red
- Year: 18 300 xmax
I'm 250, XL, Bikerzbitz......
- Color: reddish
kawasaki KX85 rear shock with preload/rebound set on softest settings.
makes a huge difference....
used one on my pcx125
i weigh 190lbs
i weigh 190lbs
- 262302737_1_644x461_klx-d-tracker-ktm-suzuki-ts-mono-shock-bandung-kota.jpg (22.77 KiB) Viewed 902 times
