Rear wheel noise...
- Color: gray
Rear wheel noise...
Does anyone experienced noise at rear wheel while u turning manually?
Re: Rear wheel noise...
jhongskiecruz wrote:Does anyone experienced noise at rear wheel while u turning manually?
There not silent. Is it an abnormal amount of noise?
Hi. What mileage is your bike, is it also noticeable with engine running and bike being pushed backwards?
- Color: gray
its only 2,800 km yes it is also noticeable when you pushing the bike backward...
Happens quite often, usually its a bearing in the clutch.
- Color: gray
its only 2,800 km yes it is also noticeable when you pushing the bike backward..Dragon_uk wrote:Hi. What mileage is your bike, is it also noticeable with engine running and bike being pushed backwards?
- Year: 2013,2014
- Color: red+redder
This noise is common in all PCXs. It's caused by a design issue in the clutch, but it doesn't mean that your scooter is about to fail. It seems to be more annoying than dangerous. It can be fixed, temporarily at least, by periodic cleaning and lubing of the parts involved or somewhat more permanently by replacing the driven face and bearing assembly portion of the clutch.
Honda is aware of the problem but apparently doesn't consider it worthy of a recall. Some of our forum members have replaced the assembly and others just do the periodic clean-and-lube or do nothing at all. As far as I know, there have been no reports of catastrophic failure of this assembly. YMMV.
Johnny
Johnny
- Color: gray
THanks Johnny for the info,meaning i can still use my bike?montliz44 wrote:This noise is common in all PCXs. It's caused by a design issue in the clutch, but it doesn't mean that your scooter is about to fail. It seems to be more annoying than dangerous. It can be fixed, temporarily at least, by periodic cleaning and lubing of the parts involved or somewhat more permanently by replacing the driven face and bearing assembly portion of the clutch.
Johnny
- Year: 2013,2014
- Color: red+redder
That's correct. Normally the noise only occurs when the rear wheel is turned with the engine not running (say while pushing the bike around to park it) or running at idle. Once the bike is underway and the clutch is fully engaged, the bearing stops turning and so the noise goes away. The bearing only turns when the bike is moving at less than, say, 5 mph.
Johnny
Johnny
Until it doesn't. Ours went from annoying to really bad eventually at around 10,000 miles. That is when we had them pull the assembly and replace it. The bearings had failed by that time, and the noise was really loud. Just keep an eye on it and if the problem becomes really obvious, it is time to replace it. The replacement assembly isn't that expensive.
On 2013 PCX that belongs to my father in law clutch bearings started to make that noise at around 11.5k and I've changed it at 13k miles.
I've made myself a spare clutch ready for when I'll need it, slowly hitting 9k miles on my 2015.
- Color: gray
thanks johnnymontliz44 wrote:That's correct. Normally the noise only occurs when the rear wheel is turned with the engine not running (say while pushing the bike around to park it) or running at idle. Once the bike is underway and the clutch is fully engaged, the bearing stops turning and so the noise goes away. The bearing only turns when the bike is moving at less than, say, 5 mph.
Johnny
- Color: gray
Thanks bro.Mel46 wrote:http://www.hondapcx.org/viewtopic.php?f ... ng+numbers
You can read up on the problem here.
Interesting that you can find the bearings. Most of us just order the assembly 23205-KWN-640 .
http://www.bikebandit.com/oem-parts/201 ... #sch794095
Assembly #8 in the picture.
At one point finding the individual parts here in the United States was almost impossible. Hopefully that is not the problem now, though installing the assembly is much faster.
Anyone know if the bearings illustrated above look like improved versions of what came out? (I heard there was a change on new replacements rather than just new copies of the old faulty style).
- Color: gray
Thanks Bro...Vancho wrote:This bearings
- Year: 2012
Some interesting fact is here.
As you can see on my previous photo (3 bearings together), 2 of them are made in Japan and one- made in Thailand.
But...
If you will see more close to the bearing "made in Thailand" you will see that its actually made in Japan.
But...
- 1.jpg (272.13 KiB) Viewed 2448 times
