Advice for riding with passenger?
I have owned my 2015 PCX150 for a little less than a month, but have ridden a smaller 50cc Metropolitan for the previous 5 years. I have no experience carrying a passenger, and probably would not feel comfortable even attempting to do so for at least another month or two.
Does anyone have any good advice for riding with a passenger? What technical aspects and safety precautions should I consider? Do I need to make any adjustments to the scooter itself?
- Year: 2012
Re: Advice for riding with passenger?
I would recommend to ride with a light passenger first. Tell him/her to keep the feet on the foot rests during the whole ride and not to step on the exhaust.
There are some simple do's and don't's... I think you can take a class
- dolls.png (225.77 KiB) Viewed 1932 times
The bike acts differently with a passenger. It takes longer to stop because the pcx only has disc brakes in the front, and no abs. Also, when you turn, the passenger must learn to lean with you. If they do not lean with you there will be problems.
Having had zero experience riding a bike before I bought my PCX at 55 years old (rode on the back of a bike maybe 3 times in my life), and now having my wife ride pillion, I would suggest ....
- Don't attempt it until you feel confident and comfortable on the bike yourself.
- If there is an empty, larger parking lot or something like that for you to practice, start there.
- If your first passenger(s) could be experienced on a bike, that would likely help. A novice passenger and a novice driver are not the best combination — trust me on this one.
- honkerman
Any change to the balance of a bike requires the operator to adapt. When a passenger enters the equation, the balance can shift without warning. I have fallen four times over the years while on a motorcycle/scooter. The first was with an inexperienced passenger on my Kymco about 7 years ago. We were turning slowly into a gravel driveway and my nephew shifted his weight. The combination of factors meant a slow speed fall. I took another nephew for a ride on the PCX back in September of this past year and he did rather well with following my instructions; I.e. Lean when I lean, don't jiggle around and hold on to me. We didn't wreck, but he is a tall gangly lad and it was difficult to adjust to the balance. Then there was my son. He rode with me since he was 12, and he's a tiny little bugger (5'2" adult height). He got the hang of it quick and I could almost forget he was there because we were both one with the bike.
All that to say, riding with a passenger is a crap shoot. These days the only passenger I generally ride with is my 10 lb Maltese. She sits in a pouch in front of me and puts her nose on my arm. I'd forget she was there, except she slobbers a little. My son never did that and he's too big to ride with me these days. Anyway, if you ride with a passenger understand that it changes the rules. You have an added variable that can be completely unpredictable. Know your bike, and know your rider. Your rider should know the bike as well and know exactly what you expect of him/her.
Make sure you both sit facing the same way, ideally facing forward.
- Year: S-wing 2014
Make sure you have the best insurance package you can afford, not just the legal minimum. I have decided for me that at age 64 and inexperienced that even when I do pass my test I do not wish to be responsible for a passengers safety on todays roads. So to practical advice based on experience I have none other than the insurance point.
RTFM!!!!!!!!!!!!
- Color: red
Mounting and dismounting is awkward for the passenger. Make it clear that they mount second only when you give okay. Then they get off first only when you give okay.
And always, always, don't fight the leaning while turning.
- flyingzonker
Riding alone is risky. Riding with a passenger is riskier.
- PingGam
- Year: 2012 PCX
Don't let the passenger sit side saddle until you are comfortable with the normal passenger position.
Current Scooters
2012 PCX 150 Black
2016 Forza 300 ABS Yellow
2012 PCX 150 Black
- Year: 2012
I would not recommend having a passenger sitting side saddle at all. I have only seen that in Asia anyway. In India I saw up to 4 people on a scooter (including one baby)PingGam wrote:Don't let the passenger sit side saddle until you are comfortable with the normal passenger position.
Always take only one passenger at a time! :-)
gn2 wrote:Make sure you both sit facing the same way, ideally facing forward.
On the bike?
Yes, and on the seat provided.you you wrote:gn2 wrote:Make sure you both sit facing the same way, ideally facing forward.
On the bike?
