Front wheel removal
davenowherejones
Front wheel removal
Post by davenowherejones »
What size hex driver do I need to remove the front axle of a Honda Forza 300?
It looks like a 16mm.
Re: Front wheel removal
You need two, one for the lock bolt and another for the spindle.
No idea what size they are though.
Oyabun
Year: `12,`15,`19
Color: black&black
Post by Oyabun »
On the PCX the spindle is 14mm and the lock bolt is 19.
Knowing the reuse engineering of Honda, I would be surprised if it would be different on the Forza.
The Forza 300 has a completely different wheel spindle attachment, there's no wheel nut, the spindle is threaded and you need a large male allen key to undo it.
Oyabun
Year: `12,`15,`19
Color: black&black
Post by Oyabun »
My mistake then. Please disregard my previous post.
davenowherejones
davenowherejones wrote:What size hex driver do I need to remove the front axle of a Honda Forza 300?
A 16 was too loose and my 17 would not fit but the Lordco store 17 did fit. I took a grinder to my 17.2 and made it a 17.
Why when the second 17mm fitted?
Sooooo. As to size I'm suspecting its probably 17mm...
MBMyer
Post by MBMyer »
So the axle needs a 17mm hex driver. What about the pinch bolt? What size hex driver is needed there for the Forza 300?
6 other previous bikes
MBMyer
Post by MBMyer »
MBMyer wrote:So the axle needs a 17mm hex driver. What about the pinch bolt? What size hex driver is needed there for the Forza 300?
Nevermind. It’s an 8mm hex driver for the pinch bolt. And the 17mm fits perfectly for the axle.
Sorry to trouble y’all for no good reason.
Michael
