Front spring diameter
- Oyabun
- Year: `12,`15,`19
- Color: black&black
Question to those who have installed new front fork springs.
In case you can still find your original spring laying around, can you please measure the outer diameter and the non-compressed length for me please?
I want to buy some front fork cartidge emulators, and I need the measurements to do some calculation before I order/start to pull the legs of my daily driver PCX.
Many thanks in advance.
- Oyabun
- Year: `12,`15,`19
Re: Front spring diameter
Anyone? I was hoping that I don't have to pull the fork to check the spring diameter- :-(
Oyabun wrote:Anyone? I was hoping that I don't have to pull the fork to check the spring diameter- :-(
So are we.
- Oyabun
- Year: `12,`15,`19
For future reference: Front spring diameter is 24,2mm
- Color: red
2013 manual specs the spring free-length at 291.8 mm or 11.49 inches.
- vamootsman
Are you installing air cartidges?
2013 PCX 150 with,
2005 Piaggio X9 500 Evolution
1982 Honda CX500 Turbo
1983 Honda Nighthawk S
- Oyabun
- Year: `12,`15,`19
J.d.b
Thanks for the info. In this topic I was asking about the diameter rather than the length. Can you please look up in the 2013 manual how much oil needs to be filled in the forks? I only have a 2011 manual but it states different spring length. Thanks.
vamootsman
I have installed YSS PD valves. It is a copy of the original Racetec Gold valve cartridge emulators and do quite some magic with the front suspension.
vamootsman
- Color: red
O.P.. your first question asked the spring free-length, you're welcome.
The 2013 manual calls for 122 +/- 2.5 CC's of fluid. They recommend 10W (SS-8).
In a collapsed fork that amount of fluid should be 75mm from the top of the fork tube.
Good luck.
Good luck.
- Oyabun
- Year: `12,`15,`19
j.d.b.
Thank you.
Thank you.
- Color: red
OP: Just curious if you've gone through installing the YSS PD valve and how it turned out. Can you post any update?
- Oyabun
- Year: `12,`15,`19
Hello Tony.Tonyx wrote:OP: Just curious if you've gone through installing the YSS PD valve and how it turned out. Can you post any update?
Sure I did. And some others followed my steps.
You can find the thread here http://hondapcx.org/viewtopic.php?f=9&t=4877
Fell free to PM me in case you have any further questions.
- Color: red
Got it Oyabun. Thanks for your sharing with the forum members:)
