Kit Cylinder 150cc Genuine for Honda PCX 125 v3 2014/2015
PowerbyPCX
Post by PowerbyPCX »
Hi!
We have now for sale Genuine Kit Cylinder Honda PCX 150cc v3 2014/2015
for the owners of Honda PCX 125 v3 2014/2015 would like change to 150cc
Price is only 99 euros!
With the discount code and the shipping cost by Air Mail is less than 119 Euros for Europe
and less than 124 Euros for USA/CANADA
http://www.powerbypcx.com/achat-kit-cyl ... 00022.html
All the parts are from Honda factory and from the PCX 150 model 2014/2015
The Kit includes:
Cylinder 149cm3 ref: 12100-K36-TOO
Piston ref: 13101-K36-T00
Ring set piston ref: 13011-K36-T00
Pin Piston ref: 13111-KGF-910
2 clips piston pin ref: 13115-KZY-700
Gasket cylinder Head ref: 12251-KZY-701
Gasket cylinder ref: 12191-KZR-600
Kit Honda PCX 150 v3 2014 2015.JPG (184.93 KiB) Viewed 2710 times
Kit Cylindre Original Honda PCX 150cc pour Honda PCX 125 v3 2014 2015.JPG (180.3 KiB) Viewed 2710 times
sendler2112
Year: 2013 PCX150
Re: Kit Cylinder 150cc Genuine for Honda PCX 125 v3 2014/201
Post by sendler2112 »
Does this run well without a remap?
Pcxdemon
Post by Pcxdemon »
sendler2112 wrote:Does this run well without a remap?
Should have no drama..worst case is just get a bigger injector.
nribeiro
Post by nribeiro »
That's what I'm talking about!!
And about the cost to install everything? Anyone know's? Or time...?
If I don't upgrade I think it might give a litle extra boost no?
ScooterMan
Post by ScooterMan »
Off the top of my head, all these parts should cost roughly $150 less just buying these in the states for U.S. buyers. You could prob get these all shipped to your door for $125 or so using an online discount parts dealer.
2015 PCX 150 (White)[/color]
Pcxdemon
Post by Pcxdemon »
nribeiro wrote:That's what I'm talking about!!
You can't install 150 kit on first gen Pcx, because the piston pin is 13mm where as the 150 model is 14mm in size. This is only good for esp 125 models.
2. You really need to upgrade the camshaft as well to get some decent gain from extra 25cc upgrade..
nribeiro
Post by nribeiro »
Mine is ESP so its good for this right? What camshaft do you recomend?
PowerbyPCX
That why we say this kit is only for the PCX 125 v3
On the PCX v3 (2014/2015) the cylinder is 149cc
On the PCX v2 (2012/2013) the cylinder is 153cc
But the Piston Pin are the same on PCX 150 v3 and PCX 150 v2
and of course it's different for the PCX v1 (only 125cc)
Sorry to contradict you but the camshaft are same between 125 and 150cc
the camshaft reference for PCX v2 2012/2013 - 125 v2 and 150 v2 is :14100-KZR-600
the camshaft reference for PCX v3 2014/2015 - 125 v3 and 150 v3 is :14100-K35-J00
Pcxdemon
Post by Pcxdemon »
No offence taken, I was more implying getting something like takegawa or yuminashi cam to go along with that bore. That would pep it up quite nicely..
nribeiro
Post by nribeiro »
Sorry but I'm a bit lost here. So my pcx 125 it's the first esp I bought it in 2013 but I think it is 2012 model cause if I'm not wrong the first generation is from 2010/2011.
This kit will fit fine on mine?
PowerbyPCX
nribeiro wrote:Sorry but I'm a bit lost here. So my pcx 125 it's the first esp I bought it in 2013 but I think it is 2012 model cause if I'm not wrong the first generation is from 2010/2011.
Not not this one because this one is only for the PCX 125 v3
We have also the kit 150 for PCX v2 for the same price:
http://www.powerbypcx.com/achat-kit-cyl ... 00040.html
and then the kit will includes:
Cylinder 153cm3 ref: 12100-KZY-700
Piston ref: 13101-KZY-700
Ring set piston ref: 13011-KZY-700
