Page 2 of 2
Re: Mirror extensions
Posted: Thu Sep 25, 2014 1:13 am
by wojtek_pl
Hi,
Anyone knows if those extenders will fit to PCX ? So far I discovered I have reverse thread too.
Posted: Fri Sep 26, 2014 4:15 pm
by fish
NeilForza wrote:dergav wrote:Neil...And remember...as Fish advised above...you will need a split washer as the screw in bottoms out before fully screwed in...if you see what I mean!
Mine came in the post yesterday so a job for the weekend
I noticed a split washer in the pack already, are you saying use one with each section? ie. where you bolt onto the bike and again where the mirror stem connects to the extender?
Also after a very quick look at the packs last night I noticed the hex/allen bolt head is quite large, any idea of the size you used as I'm positive I don't have one that large
It's an 8mm allen wrench....and I have the washer directly under the black extension base to 'lift' the allen bolt a touch so it does not bottom out in the threaded part of your scooter. Otherwise the allen bolt 'bottomed' in the scooter hole and the whole enchilada would not tighten.
Without the washer I found that I had mounted two reverse thread propellers on my scoot.
Posted: Sat Sep 27, 2014 3:53 am
by pcxpower
wojtek_pl wrote:Hi,
It's strange... my PCX is also a 2014 model, like yours (2015 model in the States) and both sides have regular thread... my PCX was built in Italy: perhaps yours was built in another country?
Posted: Sat Sep 27, 2014 6:55 am
by fish
pcxpower wrote:wojtek_pl wrote:Hi,
This is because you are above the equator.
Honda Co. are very smart people to think of this! :-)
Posted: Sat Sep 27, 2014 2:44 pm
by pcxpower
Posted: Mon Sep 29, 2014 12:39 am
by NeilForza
I fitted mine over the weekend and this morning’s ride into work was the 1st time used.
What a great difference they made, now I can glance at my mirrors and see what’s coming. No more looking at the mirror and shifting to the side a bit to see!
I would recommend these for sure, these or longer mirrors
Posted: Mon Sep 29, 2014 5:10 am
by fish
NeilForza wrote:I fitted mine over the weekend and this morning’s ride into work was the 1st time used.
Yes, the first thing I do with a new bike is fit some mirrors that work! At my age, (&at the speed I ride)most of the exciting stuff is happening behind me. All the mirrors look cool on the showroom floor ....very few of them work as intended. Glad you're safer now! Regards, Fish
Posted: Mon Oct 06, 2014 4:59 am
by riderthailand
Any idea if convex mirrors for Forza available
Posted: Sun Aug 28, 2016 2:38 pm
by Dufus
fish wrote:These worked well for me on my new Forza.
The allen screw/bolt is slightly too long...bottoms out in the brake lever housing hole. I just added one thick split washer and it snugged right up with no further issues.
Wasn't certain if these would work....the lefty threads on both sides of the Forza confused me.
Now I can see better behind me.
http://www.ebay.com/itm/400731358154?_t ... EBIDX%3AIT
Thanks Fish! $10 vs. $116? What's not to like?!
Posted: Sun Aug 28, 2016 4:16 pm
by fish
Dufus wrote:fish wrote:These worked well for me on my new Forza.
My final, and best solution to the Forza mirror problem...was fitting a pair of Honda 500X mirrors.....exact same Forza mirrors but with perfectly longer stems!
Keeping the Honda OEM look....much better than the extenders goofy appearance.
Posted: Sun Aug 28, 2016 4:59 pm
by fish
fish wrote:Dufus wrote:fish wrote:These worked well for me on my new Forza.
My final, and best solution to the Forza mirror problem...was fitting a pair of Honda 500F mirrors.....exact same Forza mirrors but with perfectly longer stems!
Posted: Sun Aug 28, 2016 9:59 pm
by Dufus
[quot="Dufus"]eThanks Fish! $10 vs. $116? What's not to like?![/quote]
Fish[/quote]
And how do they interface with the tall one-piece Givi windscreen? Any parts collisions at full steering lock? And since it's now appeared as both 500F and 500X, which is it, or are they the same?
Posted: Mon Aug 29, 2016 3:16 am
by chicaboo
Dufus wrote:and since it's now appeared as both 500F and 500X, which is it, or are they the same?
I googled the images for both bikes, and I can't tell the mirrors apart. So maybe they are the same?
Posted: Mon Aug 29, 2016 5:35 am
by fish
Sorry for confusion...my son has the X ....not the F -- he reminded me.
Visit a Honda motorcycle dealer...you'll see longer stem Forza mirrors on the 500X.
Short answer for Forza owners: great OEM looking mirrors with safer rear view for larger riders.
Posted: Mon Aug 29, 2016 5:44 am
by fish
Dufus wrote:[quot="Dufus"]eThanks Fish! $10 vs. $116? What's not to like?!
Fish[/quote]
And how do they interface with the tall one-piece Givi windscreen? Any parts collisions at full steering lock? And since it's now appeared as both 500F and 500X, which is it, or are they the same?[/quote]
Would not think a longer mirror stem will cause any interference with any screen unless your present mirror body is inside the cofines of the screen itself. . Longer stems move mirror out maybe 1.5" - 2.0"....stem is in same place as orig Foza mirrors.
Posted: Mon Aug 29, 2016 5:02 pm
chicaboo wrote:Dufus wrote:and since it's now appeared as both 500F and 500X, which is it, or are they the same?
Yes, the mirrors on the CB500F and CB500X are exactly the same.
Right:
http://www.bike-parts-honda.com/microfi ... Z-J40.html
Left:
http://www.bike-parts-honda.com/pieces- ... F+ABS.html
Posted: Wed Aug 31, 2016 6:13 pm
by MBMyer
Here's a picture of a stock Forza mirror sitting next to a CB500X mirror:
older post with picture
I like the longer stem; it allows me to see what's behind me more quickly.
MMe
Posted: Sat Sep 03, 2016 12:32 pm
by Road-Dog
here was my solution that works extremely well and was dirt cheap
Posted: Sat Sep 03, 2016 5:09 pm
by fish
Road-Dog wrote:here was my solution that works extremely well and was dirt cheap
What was is it?
Posted: Thu Sep 08, 2016 5:28 pm
by MBMyer
fish wrote:Road-Dog wrote:here was my solution that works extremely well and was dirt cheap
What was is it?
He cut the mirror arms, cut a piece of aluminum tubing, slid both parts of the mirrors into the tubes, added epoxy and some paint. Note the ridge near the bend above where the mirror screws into its mounting hole.
Cf. his post in the "Submarine Work" thread:
http://hondapcx.org/viewtopic.php?f=21&t=6606
