Hello everyone! Just Bought a pcx 150 and I don't know if this is an issue or not so I'm gonna try to explain as best as possible. After recently trading in my elite 110, I Bought a pcx brand new today from Honda House in Richmond Virginia. No miles on the odometer. Had a blast riding home, but I noticed that whenever I used the turn signal i could hear a slight buzzing sound coming from the turn signal, right as i turned it on. it doesn't keep happening, its only right as i activate the signal, then it stops and continues as normal. Im not sure if this is normal, I created a video for people to understand.
http://www.youtube.com/watch?v=nts6u1eX ... e=youtu.be
Thanks for the replies!
Mike
New pcx owner issue
- Year: 2014 forza
Re: New pcx owner issue
To me it sounds like chatter from the turn signal relay. Just drop by the shop where you bought it and show them. Easy warranty fix.
- Color: red
mine has always done this, figured it was just how it was. I just get on and ride it
Hmm, hope not all new model PCX's do this, doesn't sound right.
Ours doesn't do that either. I think you need to take it to the dealer. They should be able to swap out the relay fairly quickly. It is a plugin module, I believe.
