Large enough?
Posted: Sat Sep 03, 2022 9:17 pm
by slowlee
Hi! I'm looking to buy a new 2022 pcx 160, I'm really excited about it but I have one question. I'm 6'3" with a 34 inseam. I've sat on it and was ok but maybe a little tight around the knees and handle bars. What is your thoughts.
Re: Large enough?
Posted: Mon Sep 05, 2022 6:59 am
by theschuman
I’m 6’2” with 32” inseam and 220lbs. I’m using the OEM seat. It’s not too bad, but I could use a little more legroom. I plan to get different seat or eliminate the “bump” at some point in the future. It’s pulling my 220lbs to about 65mph on the freeway.
Re: Large enough?
Posted: Wed Sep 07, 2022 1:58 am
by ChibaPhil
I'm a leggy 6'2" with prob. 34 inch+ inseam. Here in Japan the PCX was the only scooter that I sat on in the engine class that felt big enough to feel 'normal'. On most others, even larger scoots such as the Suzuki Burgman, the handlebars would banging against my knees at full handle lock. PCX feels good in comparison. I rotated the handlebars up somewhat (can't do it too far as the brake lever assemblies are fixed into the bar and can't be rotated) and that helped with upper body comfort. Won't ever be stretching out my legs on the stock seat, but I've been eyeing a custom seat from Thailand for a while now and might eventually try one. For example, this shop gives you the option to move the back rest hump rearward for taller riders when you order:
http://www.mpmotorseat.com/HONDAPCXSEAT
Or there's this option that really tempts me, which raises the front and eliminates the hump entirely, so higher and nothing to stop you sitting further back.
http://www.mpmotorseat.com/HONDAPCXSEAT ... LA004.html
Re: Large enough?
Posted: Wed Sep 07, 2022 6:01 pm
by slowlee
Thanks for the information. Do you know if bar risers could be used to add a few millimeters of space.
Re: Large enough?
Posted: Wed Sep 07, 2022 6:31 pm
by ChibaPhil
Regarding handlebars, they are mounted like a motorbike's bars, without any surrounding plastic and no built-on instrument cluster; I was able to rotate them myself and I'm a complete know-nothing mechanically when it comes to bikes. I've seen PCX bar-riser kits online--not sure if you have to do anything with cables etc. as well. Suspect there is enough slack that you can raise them a couple of cms without issue.
(Actually, just looked and here's a thread from this site:
viewtopic.php?t=2153)
Plus you could replace the bars themselves with anything of suitable diameter, and no doubt there are tons of after-market PCX-specific options too.
Re: Large enough?
Posted: Sat Apr 08, 2023 7:07 am
by A9ballkid
ChibaPhil wrote: ↑Wed Sep 07, 2022 1:58 am
Not sure if there could be a difference in other countries models or what not…but at least in the USA the 2021 PCX brake assembly is absolutely rotatable for customizing fit. I’ve rotated both the handlebars and the brake levers to get things “just right”.
Re: Large enough?
Posted: Wed Apr 26, 2023 6:34 pm
by ChibaPhil
A9ballkid wrote: ↑Sat Apr 08, 2023 7:07 am
Interesting, I have a Japanese 2019 PCX and when I asked the shop (here in Japan) if they could rotate the brake assemblies for me they told me they were fixed through a hole in the handlebars. Never checked myself, maybe I should..
Re: Large enough?
Posted: Sat Apr 29, 2023 8:10 pm
by ChibaPhil
ChibaPhil wrote: ↑Wed Apr 26, 2023 6:34 pm
Checked again and realized I misspoke--I meant the
switch assemblies, not brake assemblies. On my bike also the brake levers are independent and can be rotated. It's the switches that are stuck in place.
