New slow pcx?
Shlouski
Year: 2021
New slow pcx?
Post by Shlouski »
Hi guys, I bought a new 2021 pcx 125 last week and I'm not sure it's running right. I've had a couple of 50cc and 125cc bikes a while back, and I'm sure they were faster. Today I was overtaken by 2 50cc bikes, even flat out I could not keep up with them. The bike tops out around 50kph up hill and around 80kph down hill, is this normal?
Conelite
Color: Blue
Re: New slow pcx?
Post by Conelite »
31mph max for a bike that should go well over 50mph? Something is definitely wrong. Return to the dealer and have them inspect it.
2017 PCX 150
Wirus Win Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
op3l
Re: New slow pcx?
Post by op3l »
Maybe check your brakes to make sure they're not staying clamped on?
Even a 125 should do well over 80 kph...
MicBergsma
Color: white 150
Re: New slow pcx?
Post by MicBergsma »
Check the rollers / sliders...
Mitch's Scooter Stuff
YouTube - http://bit.ly/MitchScooterChannel
Instagram - http://bit.ly/2fB8gay
lion_typer
Re: New slow pcx?
Post by lion_typer »
Id possibly ride 1,000 miles to let the engine break in.
Yorkie150
Year: 2018/19
Color: RED
Re: New slow pcx?
Post by Yorkie150 »
buy a brand new bike......then try and see what its top speed is ???? receipe for disaster waiting to happen...Let it bed in / run in....slowly and carefully....done properly it will run for thousands of miles...done incorrectly ....a new engine / new bike very quickly :)
Red Thunder
Re: New slow pcx?
Post by Red Thunder »
I say check the brakes also. Put it up the center stand and turn the rear wheel by hand then squeeze the rear brake then see if the rear wheel is hard to move or spins freely.
I had this happen to me as well , If hat is the case you may need to remove the rear wheel and make sure the brake pads are seated correctly. Mine was off somehow on the part that moves to spread the brake pads apart and it was stick and the brakes would stay locked up after I used the rear brake.
A pain to get to butt fixed the problem,
I did notice also when I changed out rollers on my variator that they were tight so I used an INDIA stone or knife sharpening stone on the side to smooth out any high spots an inconsistencies in the roller. It worked out just fine. The stone is MUCH more forgiving than if you were to use a file or sand paper
SantinoInc
Color: Gray
Re: New slow pcx?
Post by SantinoInc »
So whatever happened with your bike? You started the thread and never told us what the issue ended up being
Charliemcmaster87
Year: 2021
Re: New slow pcx?
Post by Charliemcmaster87 »
Hi did you manage to resolve the issue i have recently picked up a new 2021 honda pcx 125 and it seems slow?
