Hi,
I have a 2018 Pcx currently on 10,718 miles.
My question is would parts from the Pcx prior to 2018 model also fit mine? If not would anyone be able to help me in finding somewhere u.k based that sells them during this lockdown.
Reason for the above is; my Pcx started with a grinding/rubbing feel through the bike when I ride it and i can also hear it, I've had my rear wheel off completely, removed the shoes and cant see anything on that side of things but my wheel stops spinning when idle on stand.
Mechanic (car/van) in my workplace had a look around and said my bearings appear to be fine and the grinding could be my belt or possibly rollers. (Uncertain 100% unless removed and looked) mechanic in question tinkers on his own bikes
I apologise if this is posted in the wrong place as couldn't see along the lines of this in FAQ, would be really appreciative for any help what so ever and any more questions please ask away and will help to the best of my limited knowledge
Mark
Parts question
- Color: red
Re: Parts question
bike-parts-honda.com in search engine, not sure if working during lockdown, also Fowlers, both supply genuine Honda parts
Re: Parts question
You should probably figure out whats wrong before asking for parts. Could be something simple or something very serious.
Diagnose is always the first step.
2017 PCX 150
Wirus Win Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Wirus Win Exhaust
Z-Bars
NCY Variator
Re: Parts question
Most likely clutch bearings, they are prone to fail on all models.
https://www.bike-parts-honda.com/honda- ... 17/1/31917
Parts 18 & 19 and if you don't want the hassle of extracting them get sub-assembly 8
If its not them, could be something final drive related.
https://www.bike-parts-honda.com/honda- ... 10/1/31917
Also there's a wheel bearing in the swingarm bracket, 17
https://www.bike-parts-honda.com/honda- ... 30/2/31917
Re: Parts question
Put your bike on its center stand, engine off. Spin the rear wheel backwards. If it is difficult and you can hear the grinding then it is the clutch bearing. Quite a few of us have had to replace them. I don't think enough grease is shoved into those little bearings, so they eventually heat up and start to go bad. Easy enough fix for those of us who have done the repairs ourselves. Shouldn't take a bike shop long.
- Gil
Re: Parts question
I'm with Mel46 and gn2, but do upload a video of the sound when you do the test that Mel46 suggested.
I have replaced those bearing before, they sound like an old blender. I bought the whole clutch pulley part from Honda. It was cheap enough.
- alx123
- Bangkok Rider
- Color: Fast White
Re: Parts question
Honda seem to give diff part numbers for diff year models but some specifications remain the same. Though, to make sure better check the exact part number of the year model of your PCX.
Here's one site i found useful to check part numbers https://www.bike-parts-honda.com/honda- ... R/PCX/2018
Some parts are interchangeable, even with Click 125i models, but they changed the part numbers. But one can never be sure which parts remains the same/changed, better stick with the part number for the year model of your PCX.
