Increase top speed
Increase top speed
Original top speed brand new 2015 PCX 150 was 68mph. One year and 8,900 miles later, I now max out at 60mph. Besides changing the belt, how can I gain more top speed. I am now driving on a 65mph road and would like to stay with traffic! Any helpful ideas are greatly appreciated! (PCX is stock except for Givi medium windshield and YSS G-Series shock absorbers)
Re: Increase top speed
I doubt a one year old belt is to blame and a new one isn't going to satisfy your need for speed anyway. Consider the NCY performance kit. In the posted link below you can find 3 links to NCY products you'll need to install. If you can do it yourself its worth your time.
http://www.hondapcx.org/viewtopic.php?f ... azon+links
here is me on the 2015 with NCY kit, yours will go much faster with stock tires
Homie, thanks! I will let you know how they work out!!
I do know that my wife's 2013 PCX 150 gained topped speed once I installed the NCY variation, drive face and 13 gram rollers, so they do work. However, I know little about the newer 2015 model. Hopefully the same things will fit it without any issues. It is hard to give you advice on a model that I don't own, but it works on the older models.Good luck! I hope it works. :-)
Mel is right, and Brent those parts still aren't listed on those websites for 2015/16 model PCX but rest easy they are quit compatible. Plus apparently the kit wears in at speeds faster with use as my bench video's has shown.
Mel that NCY Kit, did you install it yourself? Were there detailed directions with the kit?? What was the cost of the kit? I have a 2013 PCX150 and it gets to the rev limiter pretty easy. I don't mind the rev limiter, but when you want to hold it wide open for miles at a stretch, I hate the engine cutting in and out. If I can fix that cutting in and out, I will definitely need a new seat. Not like a diesel where the governor just tapers off at set RPM, no oscillating.Mel46 wrote:I do know that my wife's 2013 PCX 150 gained topped speed once I installed the NCY variation, drive face and 13 gram rollers, so they do work. However, I know little about the newer 2015 model. Hopefully the same things will fit it without any issues. It is hard to give you advice on a model that I don't own, but it works on the older models.Good luck! I hope it works. :-)
2013 PCX150, GIVI tall w/s, Hondaline topcase, Tusk 15mm handlebar risers, NCY Variator, NCY Drive Face, NCY 13gram rollers. (I put a brand new Honda OEM belt on), R- Michelin City Grip, Front- Michelin City Grip, 10w30 syn with 2oz of MotorKote, GrabOn grip covers.
2013 Honda CRF250L
2-2005 Honda Metropolitan's,
I have always had big displacement road bikes. I'm now into the "small revolution."
I just need one more 2 wheeler!!
2013 Honda CRF250L
You can buy a fuel controller, remove the rev limiter and change the valve springs.ScooterAddict wrote:Mel that NCY Kit, did you install it yourself? Were there detailed directions with the kit?? What was the cost of the kit? I have a 2013 PCX150 and it gets to the rev limiter pretty easy. I don't mind the rev limiter, but when you want to hold it wide open for miles at a stretch, I hate the engine cutting in and out. If I can fix that cutting in and out, I will definitely need a new seat. Not like a diesel where the governor just tapers off at set RPM, no oscillating.Mel46 wrote:I do know that my wife's 2013 PCX 150 gained topped speed once I installed the NCY variation, drive face and 13 gram rollers, so they do work. However, I know little about the newer 2015 model. Hopefully the same things will fit it without any issues. It is hard to give you advice on a model that I don't own, but it works on the older models.Good luck! I hope it works. :-)
Changing the variator, rollers and drive face is easy. The cost is a little over $100, but for a 10 mph increase in top end it is well worth it. You really don't need instructions IF you have a service manual.
http://www.corsportusa.com/2010-honda-p ... ights-13g/
http://www.corsportusa.com/2010-honda-p ... rive-face/
http://www.corsportusa.com/2010-honda-p ... on-pulley/
Mel and Homie,
Either of you had any feedback on J. Costa Variators?
Thanks,
Brent!
Thanks,
Brent!
Nope... and I think I can speak for Mel since I've read his stuff for years.Brent wrote:Mel and Homie,
Thanks,
Brent!
I know nothing about them, as home knows, but I did a search on this forum to see where it was discussed previously.
http://hondapcx.org/viewtopic.php?f=19& ... it=J+Costa
Looks like it was in our discussion about the NCY variator. I guess waspmike is familiar with it.
