Hey Everybody,
I have a 2019 Honda Forza 300 and unfortunately the 12v Socket in the left glovebox stopped working. :/
I was trying to check the fuses, however, I can only open 2 fuse boxes from the 3. Somehow the thin one is stuck...
(The fuses, that I could check were okay)
Does somebody have a wiring diagram, or any idea on which fuse the socket is located?
Thanks for the help!
12v Socket doesn't work in my Forza 300 (2019)
Re: 12v Socket doesn't work in my Forza 300 (2019)
Probably the fuse as it is a 2 amp fuse I think. If you try and use anything powerful at all, it will blow.
Probably the fuse as it is a 2 amp fuse I think. If you try and use anything powerful at all, it will blow. I blew mine a while ago and the fuse was in one of the fuse boxes.
