Kill Switch Corrosion
J.Pow!
Post by J.Pow! »
Hey what’s going on everyone! I’m riding a 2015 PCX and I’ve seen a few ppl mention that corrosion can get inside the kill switch preventing the bike from coming on. Outside of spraying wd40 in the switch, have you guys done to rectify the problem? Or did the wd40 do the trick?
Thanks in advance!
springer1
Year: 2018
Re: Kill Switch Corrosion
Post by springer1 »
If a bike is stored outside, put it under a rain-proof cover.
J.Pow!
Post by J.Pow! »
springer1 wrote: Fri Apr 16, 2021 6:38 pm If a bike is stored outside, put it under a rain-proof cover.
Agreed! But I bought it used and the corrosion has already taken place! I’m now trying to figure out how to deal with it!
J.Pow!
Post by J.Pow! »
J.Pow! wrote: Fri Apr 16, 2021 6:42 pm
Agreed! But I bought it used and the corrosion has already taken place! I’m now trying to figure out how to deal with it if that makes sense.
springer1
Year: 2018
Post by springer1 »
wd40 is a good start (WD stands for Water Dispersant) , but it's not a lubricant and on its containers doesn't claim to be. Others in the group may know of something better, but I'd just use some sort of spray oil to help lubricate the switch and prevent any further corrosion
J.Pow!
Post by J.Pow! »
springer1 wrote: Fri Apr 16, 2021 8:28 pm wd40 is a good start (WD stands for Water Dispersant) , but it's not a lubricant and on its containers doesn't claim to be. Others in the group may know of something better, but I'd just use some sort of spray oil to help lubricate the switch and prevent any further corrosion
Makes sense! Thank you for the help and reply!
Year: 18 300 xmax
What you want is CRC-656....a penetrant and elec contact spray...made for electrical switches.....kills/eats corrosion. Spray your key hole as well , if you have one.
J.Pow!
Post by J.Pow! »
AWESOME!! Thanks so much!! 💪🏾💪🏾
We used CRC when I was in the Antarctic. The military depends on it in bad weather and at sea. It works well.
J.Pow!
Post by J.Pow! »
Mel46 wrote: Mon Apr 19, 2021 10:25 am We used CRC when I was in the Antarctic. The military depends on it in bad weather and at sea. It works well.
Awesome! I’ll definitely be getting some! Thanks!
