gear oil
kappachino
Year: 2012
gear oil
Post by kappachino »
about a year ago i bought a 2012 pcx and with the coming season i want to change the oils, the previous owner used 10w40 oil for the engine and 80w90 for the gearbox (see the picture), should i change it for another or use the same oil
raito
Color: matte silver
Re: gear oil
Post by raito »
How many kilometres have you done on the previous owners' oil? How do you know what oils he used? You go to the same place he changed oils and they have the records?
kappachino
Year: 2012
Re: gear oil
I asked him what oils he used and he showed me the ones in the picture, in addition I have the service book, the oil was changed in May 2020, and I drove about 3 thousand kilometers on it
raito
Color: matte silver
Re: gear oil
Post by raito »
The user manual does not say anything about sticking with the same oil.
kappachino
Year: 2012
Re: gear oil
The question is whether this oil is suitable for this transmission or not
Re: gear oil
I thought the manual said to use the same oil for both (no special gear oil needed for the small final drive chamber as it has an easy life and oil comes out looking like it went in - after 2 years). Most of us use the same oil and never have issues - fully synth 10w30 / 10w40 seems fine.
springer1
Year: 2018
Re: gear oil
Post by springer1 »
iceman wrote: Sun Mar 14, 2021 2:12 am I thought the manual said to use the same oil for both (no special gear oil needed for the small final drive chamber as it has an easy life and oil comes out looking like it went in - after 2 years). Most of us use the same oil and never have issues - fully synth 10w30 / 10w40 seems fine.
Yep.
pcx888
Color: pearl white
Re: gear oil
Post by pcx888 »
I use Mobile One 10w30 no prolbems here.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
TheDoors
Re: gear oil
Post by TheDoors »
I've used a 75w-90 full synt specific for gears despite of the Honda manual recommendations and it's very smooth, now I am at 2K kilometers with it
Year: 18 300 xmax
Re: gear oil
You can use whatever you want in the back end of this bike. There’s no combustion to dirty it up, no hi temp, and you’re putting all of 13.5 hp through the gears. I used mobile 1, and after a year it comes out looking exactly like it did when it went in.
Re: gear oil
Exactly, same with the Catrol Power 1 racing fully synth - you would not know it's been used. The manual states use the same engine oil for the final drive. It only matters for high end motorcycles where the special oil shares lots in common with normal 10w40 but has added ingredients for the purpose - none of which matters here.
springer1
Year: 2018
Re: gear oil
Post by springer1 »
My PCX wasn't accelerating worth beans. Then I added castor oil into the final drive. Problem fixed.
Yorkie150
Year: 2018/19
Color: RED
Re: gear oil
Post by Yorkie150 »
castor oil ??? or castrol ?
springer1
Year: 2018
Re: gear oil
Post by springer1 »
Yorkie150 wrote: Sun Mar 28, 2021 6:50 am castor oil ??? or castrol ?
Ooops, I'm incorrect. Don't put castor bean oil in your PCX. You can mix some with your 2T oil for your vintage 2 stroke scooter, but don't use anywhere in your PCX.
