Engine seems to start slower than usual
150pcxer
Color: Silver
Post by 150pcxer »
Recently, when I pressed the left brake lever together with the engine start button at the same time, it seemed to hesitate for a bit before starting up.
What are the possible causes?
How does the PCX start its engine up?
tjupille
Color: red
Re: Engine seems to start slower than usual
Post by tjupille »
My 2013 did the same thing. Turned out to be a weak (old) battery. New battery = all is good.
Coasting
Post by Coasting »
+1 for the battery.
Just be aware that they can deteriorate pretty quickly from there meaning that "you ain't going nowhere" (to use some frightfully bad english). I got about 4 years out of my OEM one.
Also be aware that there's often quite a variation in prices; I got my replacement from a specialist battery shop at less than 2/3 (closer to half) the price others were charging (having said that they do give me trade rates).
As an "aside" I actually carry a small 2AH gel-cell lead acid battery in my top box so that I can self-jump-start if I leave the key turned on accidentally (something I'm prone to do in my old age from time to time). It's pretty small & pretty cheap - and does the job. Also made up a couple of leads that go from the battery push-on type tabs to some small "jump start" type connectors.
Conelite
Color: Blue
Post by Conelite »
The Honda PCX uses a Stator in conjunction with the Flywheel. This is all behind the radiator.
Screen Shot 2020-10-12 at 2.40.24 PM.png (189.87 KiB) Viewed 321 times
2017 PCX 150
Wirus Win Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
