Regularly grease the centre stand
superandyp
Post by superandyp »
If the mother in law comes around, hey great opportunity, go grease the centre stand. Got an important event in you're life you should be spending all of you're time preparing for like a wedding or birth of a child. Forget about it, go grease you're centre stand.... I found out the hard way, had to cut mine off with an angle grinder.
Re: Regularly grease the centre stand
Whip your shaft out and lube it up good. :D
gn2 wrote:Whip your shaft out and lube it up good. :D
A touch Devo there...
Now whip it
Into shape
Shape it up
Get straight
Go forward
Move ahead
Try to detect it
It's not too late
To whip it
Whip it good
big bear
Color: silver
Post by big bear »
geez im going to the garage right now and do some greasing
Conelite
Color: Blue
Post by Conelite »
Is it just a Shaft/Pin that holds the whole thing?
2017 PCX 150
Wirus Win Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Conelite wrote:Is it just a Shaft/Pin that holds the whole thing?
Yes.
Pin sits in two lugs cast into the crankcase.
gn2 wrote:
Now whip it
Into shape
Shape it up
Get straight
Go forward
Move ahead
Try to detect it
It's not too late
To whip it
Whip it good
Devo were great.
tomtomclub2005
Post by tomtomclub2005 »
I did the center stand maintenance while in confinement- it was'nt getting back in place. Had I waited longer it would have surely seized- don't wait for this to happen! The pin was a bitch to get out- it bent with the pliers trying to get some leverage. Thankfully i was able to hammer it back in shape afterwards. Thanks GN2 for the tutorial...
you you wrote:
gn2 wrote:
Now whip it
Into shape
Shape it up
Get straight
Go forward
Move ahead
Try to detect it
It's not too late
To whip it
Whip it good
Devo were great.
Indeed they were.
So scary to think that "Whip it" was four decades ago.
Where did the time go?
