Speedometer Console Backlights problem!
- Year: 2012
PCX 150 2012 - Having some problems with the backlighting of the speedo console and fuel gauge.
Looks like the main LED/Bulb for the speedo part needs replacing as I don't have any light, the needle still glows red though.
The fuel gauge is now also on it's way out, flickering on/off all the time.
Anyone here been successful in repairing/replacing these bulbs ?
Maybe someone has a photo of the speedo assembly showing the main circuit board with the bulbs in situ?
It would be nice to identify these bulbs before I dismantle so I could get them in stock ready.
Appreciate any advice, thanks in advance.
Re: Speedometer Console Backlights problem!
Did you check the connection in the back of the instrument panel? It sounds like something is loose. If not, then you may need a new instrument panel.
In my experience, flickering lights are far more likely to be an indication of a connection problem than a bulb fault.Perce2 wrote:The fuel gauge is now also on it's way out, flickering on/off all the time.
I'd suggest starting by popping off the grill, windscreen, and cover (really easy when you know how - let me know if you need a hand with it) then inspecting the large connector to the back of the panel. Just be sure to have a replacement zip tie on hand to replace the one you'll need to cut to get the cover away from the connector.
I'd be inclined to unplug / replug the connector a few times and wiggle a few wires to see if there's any change to what you're seeing.
Hope this helps.
- GeorgeSK
- Year: 13PCX,15Forza
- Color: Both Red
+1 on the connection. Bulbs crap out and that is that. Flickering strongly suggests intermittent connection.
- Year: 2012
Tried all of the above without any success...
Could just do with some idea of the kind of LED's used on the board so I can them in stock prior to removing the whole speedo module for further investigation.
As I use the bike daily, don't want to get the bike stripped then have to put it all back together whilst waiting for parts to arrive, then have to repeat the process to fit them (if needed). They only cost a few pennies, so even if I don't need them it doesn't matter.
Thanks for the suggestions though.
I did a bit of Googling for you - and looked up the manual - nothing of significance found I'm afraid.
From the manual we can see that they're LEDs, but no further breakdown.
- 1.JPG (57.47 KiB) Viewed 2183 times
- Year: 2012
Thanks Maverick for the schematic/wiring colour code pin-out.
Like you say, at least we know they actually use LED's now in the speedo console as opposed to normal dash bulbs. Just don't know what type, size, manufacturer details etc.
Main "backlight" showing 2 led's connected in series, that's why there is total darkness. Instead of just losing some light, when either single led has fused, you lose the lot!
My theory so far, is that I have an LED fused and a separate bad connection, fuel gauge issue. Probably on the board or with the fuel gauge itself. Notice the fuel gauge is not actually represented on that schematic, unless it's the LCD (at the top). Could be a totally separate unit in the console.
Cheers!
Cheers!
Good luck - in terms of parts, the complete speedo is probably the next highest assembly.Perce2 wrote:Thanks Maverick for the schematic/wiring colour code pin-out.
Cheers!
Let us know how you get on.
- Year: 2012
I'm located in Thailand, the cost here quite expensive for a complete unit.
As an electrical engineer, a repair is more cost effective if I can obtain the parts required.
I'll keep you updated with any progress.
Hope it goes well for you. I spent 7 years as an Avionics Tech in the RNZAF - about 4 of them doing component level circuit board repair. My concern with things like this is that sometimes they make them darn difficult to get to - hope that's not the case for you. By all accounts getting it out isn't tooooooooo bad - (I use an online manual from Cyclepedia).Perce2 wrote:I'm located in Thailand, the cost here quite expensive for a complete unit.
It's more likely a connection issue as stated, perhaps poor soldering on the inner circuit board, but mostly likely if not a multi way connector issue, some bad wiring from ECU/Battery to console - could be a poor earth connection or such. The circuit diagrams can be found searching this forum or google, so best grab them all.
Best I can tell, the power for the lights is drawn off the common power for the rest of the panel - so something external like the connector couldn't cause only a couple of the lights to flicker - so I'd think it's more likely to be inner circuit board.iceman wrote:It's more likely a connection issue as stated, perhaps poor soldering on the inner circuit board, but mostly likely if not a multi way connector issue, some bad wiring from ECU/Battery to console - could be a poor earth connection or such. The circuit diagrams can be found searching this forum or google, so best grab them all.
- Year: 2012
I see another couple of site members have the same issue with the same year model, so I don't appear to be unique with this one.
I agree with Maverick, power is obviously reaching the circuit board as the other LED's are working fine, ruling out connector theory. I have also had the top off and cleaned and checked all plug terminations, they are fine. The problem appears to be in the speedo assembly itself where we are lacking information so far.
Just found out my mate has a friend who owns a local motorbike shop, he's currently on his way to see if we can obtain a second hand unit (working or not) for further inspection and clues....watch this space!
Partzilla only seem to have the 2013 speedometer assembly, least I could not see anything when searching for Honda > Scooter > 2012. Here's a link - the whole assembly, if matching yours, is $146 + shipping.
https://www.partzilla.com/catalog/honda ... peedometer
Out of curiosity, I'm wondering if changing the console would reset the odometer? I'm presuming it's recorded in the console and not transmitted from the ECU? (might need to do that if my bike gets to 100,000km (well on the way now at 34,000).iceman wrote:Partzilla only seem to have the 2013 speedometer assembly, least I could not see anything when searching for Honda > Scooter > 2012. Here's a link - the whole assembly, if matching yours, is $146 + shipping.
