problem about torque.... (pcx125 '13)
hi guys. i'm korean pcx owner.
i have a question about pcx parts. i have a pcx125 (2013)
i replaced my pcx125(2013) parts to 15-17 pcx125 parts (drive-belt, weight-roller, drive-face, clutch-outer)
so, my pcx's torque became so weak now.. (0-60kph 9s.. before replacement, 5~6s)
is that different belt size '13 with '15-'17 ???
thx
thx
Re: problem about torque.... (pcx125 '13)
I'd reinstall the old belt....and see what happens.
You might not have the correct new belt (all your new parts OEM HONDA ?, or not?
You can check parts compatibility here: https://www.bike-parts-honda.com/
fish wrote:I'd reinstall the old belt....and see what happens.
all parts are OEM HONDA stock all new pcx(15-17).
Do I reinstall only the belt??
thx for ur reply
i have no old belt. all replaced by honda engineer..
i have no tools.. i think engineer discarded my old belt
What did the mechanic say, when you explained your loss of power?sjdkv234 wrote:i have no old belt. all replaced by honda engineer..
i will visit honda tomorrow.fish wrote:What did the mechanic say, when you explained your loss of power?sjdkv234 wrote:i have no old belt. all replaced by honda engineer..
he said all '15-'17 parts which replaced are same with '13
but i cant believe it..
so, i need some information about these..
- Year: 2010
You might have had heavier weights put in there's a chance 15 - 17 might be 18kg and you need 15kg
Or it's most likly belt as 2015 is different spec to 2013 this could be the cause
And I would make the garage replace it what dumb Mechanic uses incorrect stuff
Belt you need is 23100-KZR-601
- Year: 2010
Also if the belt that's been put in is ribbed on outer belt then its defo incorrect one
he should have part number for belt
Also you can use 23100KWN901
- Year: 2010
I reckon the dealer that did the work probably couldn't be bothered ordering the stock and used what they had instore
