keeps bogging at full throttle only, really need help to fix
Posted: Fri Apr 12, 2019 11:46 pm
by MaLLoc
Honda PCX150 2015,
this has been going on for a while now, and I thought it had to do with my coil wire spark plug, the connection plug was broken.
I finally got another coil and wire/plug and a new spark plug got it installed and still having the same issue.
When I pull the handlebar throttle all the way ( no matter if I'm going 0 mph of full speed ) once I pull it all the way the bike just Boggs, if I let off 1-2 mm it goes back to going full speed or normal accelerating.
Re: keeps bogging at full throttle only, really need help to
Posted: Sat Apr 13, 2019 4:24 pm
MaLLoc wrote:Honda PCX150 2015,
Have you checked that the air intake/filter is clear?
Posted: Sun Apr 14, 2019 12:02 am
by MaLLoc
I have not recently, however it was doing this when I had changed it to a new one, but I will look at it
Posted: Sun Apr 14, 2019 12:35 am
So it has being doing it for a while? Any significant event just before it started? Servicing, mods etc?
I’d change the plugs and set the valves first, giving the engine a good look over at the same time. Just to eliminate things.
I’d be suspecting air/fuel if it was bogging at full revs rather than a misfire.
Posted: Sun Apr 14, 2019 2:45 am
by MaLLoc
no mods , just dr pulley sliders , yes been doing it for a while and i do not recall anything besides noticing the broken coil spark wire plug , , coil wire and spark plug just changed and still doing it, i dont think doing the valves will do anything since this happens at 0 speed and runs fine as long as i dont twist 100 percent , if i twist 98% everything runs good and the bike goes up to 70 mph ( just a pain in the ass trying to keep twisting to 98% throttle ,
is there some dam sensor in the throttle butterfly thats giving bad feedback to the engine at 100% ???????
Posted: Sun Apr 14, 2019 7:13 am
by DAB
Not familiar with your model but do you know if there is a throttle position sensor (TPS)?
Posted: Sun Apr 14, 2019 8:27 am
by Old Grinner
You may be on to something . . ..
This thread initiated by alx123 was on the forum some time ago and when the "TPS" was replaced on his machine it solved the problem. Evidently it's more common on PCX's than one would think.
https://www.hondapcx.org/viewtopic.php?f=19&t=9329
Posted: Mon Apr 15, 2019 5:19 am
by MaLLoc
ok, thanks, that is exactly sort of what I was thinking had to be wrong, so now I know what I need without the dignostic tool,
Posted: Mon Apr 15, 2019 8:30 am
Let us know how it goes?
Posted: Tue Apr 16, 2019 4:43 am
by MaLLoc
you you wrote:Let us know how it goes?
honestly, the part is like 60 bucks and its not worth it since the throttle works perfectly till last 2% , if that changes then i would change the part out
Posted: Tue Apr 16, 2019 4:23 pm
MaLLoc wrote:you you wrote:Let us know how it goes?
At least you got to the reason even if you are just going to live with it.
No need to say thank you.
Posted: Fri Apr 19, 2019 5:22 am
Might be possible to reset the TPS rather than buy a new one.
Is the throttle cable slack set to the correct amount?
Posted: Tue Apr 23, 2019 3:48 am
by MaLLoc
gn2 wrote:Might be possible to reset the TPS rather than buy a new one.
I was also wondering if something could be reset for a while, hasn't been touched since owned it, and there doesn't seem to be any slack at all
Posted: Tue Apr 23, 2019 5:52 am
There should be slack in the throttle cable, the throttle handle should rotate a couple of millimetres before the cable inner starts being pulled through the outer.
