Page 1 of 2
Honda pcx does not exceed 90km / h, I think electric failure
Posted: Mon Jan 21, 2019 2:35 pm
by gestosan
Hello friends, I have a problem with my pcx of 2014 and it is that the bike remains at 90km / h, I think it is electrical failure and I would like to have the workshop manual and the values to measure coil and cdi and be able to check that they are Well, if someone can help me out, please. Thank you.
Re: Honda pcx does not exceed 90km / h, I think electric fai
Posted: Mon Jan 21, 2019 2:41 pm
by Jge64
That's 55 mph, not too much wrong with your bike if it'll do 55… Probably a Worn belt or weights....
Posted: Tue Jan 22, 2019 11:41 am
by Cube
Mine tops out at 58mph, so I agree with Jge64
Posted: Tue Jan 22, 2019 12:29 pm
It obviously depends on whether you have a 125cc or a 150cc engine. Either way, change your belt and check your weights for wear.
Posted: Tue Jan 22, 2019 1:03 pm
Also check oil not overfilled, air filter clean, brakes not dragging and tyres correct size and inflated to correct pressures.
Posted: Tue Jan 22, 2019 2:52 pm
by Cube
Pretty much check everything but electrical.. lol
Posted: Tue Jan 22, 2019 5:42 pm
Also check there isn't a parachute tied to the tail....
Posted: Wed Jan 23, 2019 6:23 am
by gestosan
efectivamente, esta mañana he salido y tenia un paracaidas atado a la cola.
Posted: Wed Jan 23, 2019 6:27 am
by gestosan
A ver, la pregunta mas concreta es si a alguien le ha pasado lo mismo con fallo en el circuito eléctrico, bobina, bujia, cdi, para que me oriente un poquito como lo arregló.De aceite, rodillos, bujía y frenos etc la moto va genial.Gracias.Ya tengo el manual de taller para comprobar con multímetro valores electricos.
Posted: Wed Jan 23, 2019 9:11 am
by MiddleRiverPCX
Is the needle stuck at 90 kph or will the bike not go over 90 kph? The wording could mean either of those, or also could mean the almost impossible never varies from 90 kph. "bike remains at 90"
Posted: Wed Jan 23, 2019 9:24 am
gestosan wrote:A ver, la pregunta mas concreta es si a alguien le ha pasado lo mismo con fallo en el circuito eléctrico, bobina, bujia, cdi, para que me oriente un poquito como lo arregló.De aceite, rodillos, bujía y frenos etc la moto va genial.Gracias.Ya tengo el manual de taller para comprobar con multímetro valores electricos.
English, please. I can't seem to get Google to translate this.
Posted: Wed Jan 23, 2019 1:44 pm
by Limey
Google Translate translated it as this, for me:
1st post:
"indeed, this morning I left and had a parachute tied to the tail."
2nd post:
"Let's see, the most concrete question is whether the same thing happened to someone with failure in the electrical circuit, coil, spark plug, cdi, so that he orients me a little bit as he fixed it. Oil, rollers, spark plug and brakes etc the motorcycle It's great. Thank you. I already have the workshop manual to check electrical values with a multimeter."
Posted: Thu Jan 24, 2019 1:36 am
by gestosan
When I accelerate to the maximum it reaches 90km / h and afterwards it is very difficult to run more, if I open and close my fist it runs a little more.
Posted: Thu Jan 24, 2019 9:09 am
Most likely to be a worn drive belt.
Posted: Thu Jan 24, 2019 11:25 am
When a PCX reaches the limiter it acts like it is hesitating and tries again and hesitates some more, back and forth. This is normal.
As the belt and rollers wear the bike's topend will decrease. This too is normal. Before checking other possible problems, check and replace the belt.
After 5,000 miles you will see a difference in topend. At 10,000 miles you will lose as much as 10 mph, and it will only get worse. As the rollers are worn they will do about the same because they are the weights that are used by the "transmission" that uses centrifugal force to set your speed.
Posted: Thu Jan 24, 2019 2:31 pm
by gestosan
The weights of the variator have been put new and the belt is not very old.
Posted: Thu Jan 24, 2019 6:09 pm
It could be the wrong belt or the wrong weights.
Posted: Thu Jan 24, 2019 9:42 pm
There have been discussions on this forum in the past about counterfeit belts, as well as the differences between manufacturers. Make sure you have a Honda belt by purchasing one from an authorized Honda dealer.
The least you should do is compare the writing on the belt on your machine with that of one that a Honda dealer sells, to make sure it is the correct one.
Posted: Fri Jan 25, 2019 8:11 am
I think the OP is pretty determined to check for an electrical problem. Let’s see how it unfolds.
Posted: Fri Jan 25, 2019 10:29 am
The electrical problem is it doesn't have a Zero SR motor and battery fitted.
