How-To: Install a Trunk
Re: How-To: Install a Trunk
jcomp5150 wrote:I just wanted to say thanks for all the info and part numbers/vendors. Here are some pics of a successful install after finding all the great advice! Thanks.
It looks good. And by the way, welcome to the forums.
kcpcx
Color: Candy Rosy Red
Post by kcpcx »
Thank you for the rack DIY. Very helpful.
I took a slightly different route for the holes, in case it helps anyone.
I didn't have a 7/8" drill bit. Some calculating showed that 3/4" is also very close to 20mm.
I used a Dremel tool with a small sanding drum to fine tune the holes a tiny bit larger after the 3/4" bit. Instead of the round file used in the tutorial. Either way works, just depends what you have on hand.
In particular, the part about removing the little white clips was helpful. Much easier to test fit repeatedly that way before final install.
'88 BMW R100RT
jon_l
Color: black PCX
Post by jon_l »
Thanks for the great write-up PCX Commuter.
I installed mine today:
black 2013 PCX150, red & black 2012 Triumph Thunderbird 1600
ahsteven
Post by ahsteven »
Hi, great tutorial!
I bought a 2011 PCX and someone has already drilled out the wholes in the back. The front two close to the seat are the same as the ones in the images. However the ones in the back are the smaller wholes next to the big ones. Does anybody know of a trunk model that will fit in these wholes?
ahsteven wrote:Hi, great tutorial!
Do you have any pictures of the holes?
ahsteven
Post by ahsteven »
Here you go!
