PCX 125 30 Liter Trunk Box
Posted: Thu Dec 27, 2012 6:10 pm
This is my first post.
I just finished my first accessory "mod" on my 2011 PCX 125. I'm planning to do some scooter camping in the spring and summer next year, so I need to add some onboard storage that will keep my gear safe and secure.
I'm planning on carrying "emergency" gear under the seat (patch kit, inflator, tools, battery tender, etc...) as well as a small backpack with my gadgets (laptop, ipad, mobile "office"). These make up the bulk of my heavy gear so I wanted them under the seat to a) keep the center of mass as low as possible and b) keep it secure and dry.
Then I decided that I wanted to add some bags of some sort. I did a lot of research on soft saddlebags and trunk bags and came very close to going that route...but there's a problem with having both a trunk bag AND saddlebags...once everything is attached you can't lift the seat! So I decided to keep looking. I thought about getting a helmet trunk (Honda OEM or Givi) but didn't want to spend that much money and didn't like that most helmet boxes are clamshell...which means half of the storage capacity is in the lid!
Then I remembered that Rubbermaid makes these tough, waterproof, lockable storage boxes and tried to figure out how to mount it to the scooter. I got pretty far down the path of replacing the seat hump with some sort of mounting bracket that I would attach the storage box to...but decided against this due to the nature of the bolts and the fear that sideways torque on the seat would crack the plastic seat pan.
So, I finally decided to split the difference. I purchased the Honda OEM rear trunk base specifically designed for the Honda PCX 125 (the model for the 150 is different, beware): Honda Part #:08L42-KWN-100MSRP for $99.95 at my local Honda dealer or get it on Amazon
http://www.amazon.com/Honda-Genuine-Acc ... 42-KWN-100
After reading the installation instructions (didn't want to pay Honda Dealer $150 to install!!) I ordered a 20mm hole saw from Amazon for $6 with prime shipping.
http://www.amazon.com/gp/product/B005CM ... 02_s00_i00
And finally I purchased the 8 gallon "Action Packer" from my local REI for $24:
http://www.rei.com/product/634286/rubbe ... cker-8-gal
I was nervous about the installation because you have to remove the rear seat cowling and drill 20mm (1") holes in it. But, it went pretty well. I removed the cowling without doing any damage, drilled the holes from the underside (Honda was nice enough to mark the drill points), test fit the installation hardware, sanded down the edges with a dremel sander, and got ready to bolt everything in place.
Before I attached the rack base, I used it as a template to drill holes in the bottom of the Action Packer box. I got it as close to the seat as possible without it getting in the way of opening...and I used the drill points that were already on the rack base (intended for mounting the Honda OEM helmet box).
Once everything was predrilled and dry fitted, I bolted the base on the scooter, bolted the Action Packer directly to the base using the included screws, bolts, and washers (I did not use the "collars" as they are specifically designed for use with the helmet box) and viola! Perfect fit!
It feels pretty sturdy and it adds a ton of usable, securable space to the scooter (and I can probably still carry a small passenger).
I've got a lot more plans dancing around in my head, but haven't made any purchases yet.
I'm hoping to carry my "campsite" in the trunk box (small stove, cookware, dinnerware, food, lights, tools/knives, etc...) and then plan to strap carry a waterproof "bedroll" to the seat between me and the box (tent, sleeping bag, sleeping pad, pillow). I'm also thinking about attaching a 1.5 gallon fuel tank to either the back of the storage box or the lid...but I’m not sure about that yet. I was also toying with the idea of attaching a solar panel to the box lid for charging gear on long trips (or battery maintenance at campsites) but I'm not sure I want to commit the lid to that just yet (considering a small luggage rack to strap down light gear).
I did install a small GPS/Nav and ran power to the battery box using a 12v adapter and battery tender lead...but I want to figure out how to run it up the steering column so that it's not flapping in the wind. I'm also pretty sure I want a tunnel bag for riding clothes, snacks, etc...so if anyone has one to recommend let me know!
Hope this post helps, and let me know if you have questions or want better pics.
Thanks!
Thanks!
