Does the 2015/16 Forza 300 utilise ACG (PCX start-system)?
erisaman
Year: 2015/Forza 300
Post by erisaman »
I understand the ACG system as standard in the PCX - but does the Forza NSS300 (pre-2018) utilise the same combined starter and alternator system? Specs state that the Forza has a "self-starter' but also states that "ACG output is 380 watt"?
If you don't stand for something - you'll fall for anything.
Re: Does the 2015/16 Forza 300 utilise ACG (PCX start-system
I believe the original model Forza introduced in 2013 has a separate starter and alternator, it definitely does not have idle stop.
The new facelifted one might do.
erisaman
Post by erisaman »
Thank you for that - I posted early morning but thought I'd check to see if our overseas cousins had posted a response... but no, you are up to it before 'the ink has dried'. Thank you again - there will be many more questions to follow no doubt.
Early shift this week, start work at 06.30 so up at crack of sparrows.
