Immobiliser PCX125
Posted: Sun May 06, 2018 9:55 am
by northernmunky
I've heard there is a way to fit an immobiliser to a PCX125 (2013 model) and suggestions on how to do this so that in the event someone tries to steal it they will be unable to get it started?
Re: Immobiliser PCX125
Posted: Wed Jun 06, 2018 9:20 am
by northernmunky
A month and no responses. Seriously, has no-one invented a simple immobiliser that only allows a complete circuit from the battery when I press a hidden button that will confuse the F out of thieves?
Posted: Wed Jun 06, 2018 9:50 am
Sorry, not much found on the topic.
Immobilizer heh? I did a quick search and came up with this:
http://www.hondapcx.org/viewtopic.php?f ... mmobilizer
Hardly helpful. Where is it that "You heard" there was a way to fit one?
Let's wait a bit longer for other's to drop in, perhaps they forgot to come back to this topic. That could happen
I do it all the time
Posted: Thu Jun 07, 2018 1:52 am
by Oyabun
I might be overly optimistic, but I don't live in a very infested area regarding bike theft, so I've never actually implemented one, but checked how could I do so if I ever wanted to.
After removing the rear body panels, on the right side of the bike there is a single wire connector attached to the loom, what seemingly connected to itself, and does not connect to any peripherial (it is a loop). It looked kinda suspicious, so I checked the wiring diagram. It doesn't show such a connector, but the brown-yellow color is for the fuel pump. Checked that if I disconnect the plug from itself - the fuel pump lost power indeed.
Based on the above I think that is the place what Honda has prepared to use as the point of "immobilisation".
I've bought a small circuitry from Ali which has two coded wireless electronic remotes sized as an RFID token and a base unit what needs 12v and has a switched connection output. After pushing the button on the remote you have two minutes to start the bike.
As I said I haven't installed this so far, and the solution needs testing. I don't know if the power is cut to the fuel pump then the idle stop function kicks in - if it is, it might be an issue what can be remedied by using a latching relay connected to the switched 12v supply of the bike.
Other option would be to use a hidden switch routed to the kickstand wiring. If the ecu senses that the kickstand is lowered (in other words the kickstand circuit is closed) it will stop the engine. Again a latching relay aould help here. If the bike is unpowered, the relay loses power, and closes the kickstand circuit, making it impossible to start the bike. After switching ignition on, one needs to push a button momentarily to get the ray energized, which cuts the shortcut on the circuit and enables starting. The push butoon can be replaced by a reed switch behind panels, what is magnetically sensitive and needs a small magnet to close - this would not even have button interface what could be found by the thieves.
Hope it helps.
Posted: Thu Jun 07, 2018 2:10 am
by Oyabun
Pictures of the connector I talk about
Note it is disconnected only for educational purposes. Normally it is permanently connected to run the bike.
The connector looks similar to an AMP econoseal single position sealed connector but I'm not 100% sure it would fit.
- Connector type
- connector_624x624.jpg (273.31 KiB) Viewed 9728 times
- Two parts of the connector disconnected
- fuel pump circuit conn-1280x960.jpg (355.72 KiB) Viewed 9728 times
Posted: Thu Jun 07, 2018 3:55 am
Top quality reply
Posted: Thu Jun 07, 2018 9:39 am
Indeed! Thank you Oyabun for going Beyond an answer. We got pics folks!!
This thread is on it's way to becoming.....
Wait for it.....
a PCX How-To
Posted: Thu Jun 07, 2018 12:50 pm
Maybe a prompt thank you from the OP?
Posted: Thu Jun 07, 2018 1:22 pm
northernmunky wrote:A month and no responses. Seriously, has no-one invented a simple immobiliser that only allows a complete circuit from the battery when I press a hidden button that will confuse the F out of thieves?
Yes, Sang Yang Motor, better known as Sym fit a mechanical immobiliser switch switch under the seat.
As seen in this review:
http://www.justgottascoot.com/symfiddle2.htm
Posted: Thu Jun 07, 2018 4:19 pm
by Cube
Someone here or on the other forum I haunt was trying to install one of these:
https://www.ebay.com/itm/SPY-5000-MOTOR ... 1267254597
Posted: Wed Jun 13, 2018 4:54 pm
I Have Heard that Fitting that Spy 5000 to a PCX is a real pain. Good luck with that one.
As for the fuel pump wire, even splicing an on/off switch there and hiding it under the seat should stop a thief from stealing your bike.
Posted: Wed Jun 13, 2018 5:56 pm
Mel46 wrote:I Have Heard that Fitting that Spy 5000 to a PCX is a real pain. Good luck with that one.
A thief with a van?
Posted: Wed Jun 13, 2018 8:19 pm
Well, it won't start at least. For the van part you will need to do something else.
Posted: Sun Jun 17, 2018 7:46 am
by d1ckyh
While it is not exactly legal, most places I go (primarily the grocery store), I try and park away from any street traffic so lifting it up and putting it in a van would be difficult. Honestly I don't go anywhere that would require me to be away from the scoot for more than 15 min. and if I go to a restaurant or something, It is always in my line of sight. Fortunately, I am able to park indoors so not concerned with theft at home.
I also do have an alarm and a alarm sticker in the center just above the gas tank lid. While neither will prevent it from being stolen, It give me a little piece of mind. Plus it is insured for theft.
Posted: Sun Jun 17, 2018 9:18 am
by easyrider
northernmunky wrote:I've heard there is a way to fit an immobiliser to a PCX125 (2013 model) and suggestions on how to do this so that in the event someone tries to steal it they will be unable to get it started?
Why bother ?? Any professional will just pick it up and off they go.
