Stahlbus oil drainer
Posted: Tue Nov 14, 2017 6:10 pm
Just bought one of these for the Boxer Cup as part of the winter fiddling. There's a bit of Homie/Monk in me.
It's a nice bit of kit, has anyone fitted one to a PCX?
Re: Stahlbus oil drainer
Posted: Tue Nov 14, 2017 6:37 pm
by Jge64
Do a search, I have one on my pcx...great mod.....
Posted: Tue Nov 14, 2017 6:50 pm
Jge64 wrote:Do a search, I have one on my pcx...great mod.....
No need to, it'll be underneath your bike if you've lost it
Posted: Wed Nov 15, 2017 11:11 am
What is the size of the inner thread on the pcx drain bolt?
It looks like you screw that device into the drain hole permanently. Then it looks like you screw in the hose when it is time to drain the oil. Good idea, but $45 is a lot of money to make it more convenient every 3,000 to 4,000 mile to drain a quart of oil.
Posted: Wed Nov 15, 2017 1:41 pm
by Jge64
Is much more convenient than “ screwing it in”...You put the permanent part of the receptacle in the drain hole. That stays with the bike. Then you have a quick disconnect auto feed hose that you can drain it into a container and not spill a drop. Uses a very high-quality surgical tubing, it is extremely flexible and does not bind in any position. Love the stuff .
all This is Not important to some, it’s very important to me because I’m in a condo where we like to keep things clean in the garage.. After drained, just disconnect the hose and you’re ready to go ....
here is more information .....I have them on all my cars and bikes. Someone will say its expensive, and yes, guess on your perspective. Very efficient and clean, therefore the price is right to me.
https://www.stahlbus-us.com/oil-drain-v ... uisuokd9d5
Fumoto is a cheaper valve but excellent, used them too.
Posted: Wed Nov 15, 2017 3:33 pm
Jge64 wrote:Is much more convenient than “ screwing it in”...You put the permanent part of the receptacle in the drain hole. That stays with the bike. Then you have a quick disconnect auto feed hose that you can drain it into a container and not spill a drop. Uses a very high-quality surgical tubing, it is extremely flexible and does not bind in any position. Love the stuff .
It does seem good. I use an oil drain pump for the PCX, which I prefer, but I cant use it on the Boxer Cup as the oil fill is on one of the heads.
Some good alternatives to loosening the bolt and having the oil run down yer sleeve. A good purchase as opposed to cup holders, phone holders, gps holders, god knows what else holders for the handlebars
Posted: Wed Nov 15, 2017 3:47 pm
by easyrider
I had one once,nice and clean device,but for me I felt the inner valve created too much restriction and slowed the flow rate too much for a good flush out of all the contaminants.Under restricted conditions could be good.I use a fumoto on my vehicles and a vacuum tank hose attachment now.
Posted: Thu Nov 16, 2017 10:54 am
I could see this device being used on a car, or even an expensive motorcycle, and it would make changing the oil on the PCX a snap. However, since the PCX is not a high end bike it just seems like overkill on it.
Someone on this forum had this great idea, which I now use for changing my oil, in which he had a piece of Velcro on the center stand that he attached a plastic funnel made from a 1 quart oil container. The oil drains into the oil collection pan through the funnel.
The only problem I have ever had with this setup has been getting the bolt out. I loosen it before attaching the funnel, but then I have to unscrew it by hand, which is difficult with the funnel attached. However, I only deal with this every 3,000 miles.
Something I added to the mix was that I put the center stand on a 1x6, which gives me another inch of ground clearance. Put a small piece of plastic drop cloth down first. Then put some newspaper on top of that. Then the 1x6. The oil change pan will be put on top of the newspaper after the bolt is loosened enough to hand turn it, and the funnel bottom will sit in the pan.
It is difficult to get the center stand lined up with the board, but practice and a little extra effort work well. I keep a bag of cheap cat litter around for cleanup afterwards. It absorbs spilled oil nicely. There shouldn't be much.
Posted: Fri Nov 17, 2017 8:09 am
by WI_Hedgehog
I built Race Ramps, so I drive a bike up the ramp onto the flat, then pull the center part of the flat section out, leaving the bike supported by the flat sections under the wheels and kickstand. That should also let all the oil drain out of the screen side of the PCX, necessitating removal of only that bolt. Squirrel isn't to 600 miles yet, so haven't tried this to see how it works.
With my luck the check valve ball would pinch some fine particles and have a slow leak. And I'd lose the special drain hose. Plus as @easyrider says the faster flow drains out more junk.
