Steering Lock
Posted: Thu Jul 27, 2017 4:47 am
by Sandymay
Sometimes my steering lock works the first time I try to put it on, and other times I need to keep moving the handlebars back to centre and then to the far left, try to lock the steering, and keep repeating if it doesn't lock.....
Is there a secret to this?
Re: Steering Lock
Posted: Thu Jul 27, 2017 5:50 am
Sandymay wrote:Sometimes my steering lock works the first time I try to put it on, and other times I need to keep moving the handlebars back to centre and then to the far left, try to lock the steering, and keep repeating if it doesn't lock.....
Yes, what you are doing
Re: Steering Lock
Posted: Thu Jul 27, 2017 10:13 am
by davenowherejones
I have to jiggle my bars when it is turned full lock to get the steering lock to work.
It is possible to turn it a few degrees too far, back it off a bit.
Re: Steering Lock
Posted: Thu Jul 27, 2017 10:41 am
I gave up trying to use mine and just put a Grip-lock on when I go to the store.
Re: Steering Lock
Posted: Thu Jul 27, 2017 11:17 am
by homie
Sandymay wrote:Sometimes my steering lock works the first time I try to put it on, and other times I need to keep moving the handlebars back to centre and then to the far left, try to lock the steering, and keep repeating if it doesn't lock..... Is there a secret to this?
Yes mam, with the wheel turned fully right, key from the off position PUSH THE KEY IN and turn it left. You will feel the key go into the ignition deeper, 1/8th of an inch or so.
This safety feature forbids you from rolling down the street, turning off the engine and turning your key fully left locking the steering. Highly unlikely anyone would do this while coasting in a full right hand turn but Honda thought to put the extra action just in case.
Re: Steering Lock
Posted: Thu Jul 27, 2017 8:06 pm
by davenowherejones
homie wrote:Sandymay wrote:Sometimes my steering lock works the first time I try to put it on, and other times I need to keep moving the handlebars back to centre and then to the far left, try to lock the steering, and keep repeating if it doesn't lock..... Is there a secret to this?
You got it right but it still seems silly. Oh well.
Re: Steering Lock
Posted: Fri Jul 28, 2017 10:07 am
by montliz44
davenowherejones wrote:I have to jiggle my bars when it is turned full lock to get the steering lock to work.
^^^^ +1
Johnny
