Hence, soft luggage saddle bags, or panniers if you will, are a good option if you need to grab something without shutting off the engine?
That being said the engine will continue to run if you put the PCX on the side stand or center stand right? Or is it only the center stand?
Example: If I was going to mail a letter could I put the PCX on the side stand while the engine was running to pull a letter out of my saddle bag without shutting off the motor? How about the center stand?
With my Roughhhouse 50 I can use the side stand or center stand and not have to shut the engine off. The thing is if the engine ticks over too fast the clutch will edge the drive belt and if it's on the side stand in lieu of the center stand you have to be quickly attentive or watch it go down before you.
