Lowering bracket, has anyone tried?
kar120c
Year: 2015 Forza 300
Post by kar120c »
Anyone has tried these? https://bikerzbits.com/forza-lowering-bracket.html
I would know if it is necessary to tune the front fork too.
I asket informations in Thai forum but is very difficult to communicate.
montliz44
Year: 2013,2014
Color: red+redder
Re: Lowering bracket, anyone has tried?
Post by montliz44 »
I have them on my Forza. They're good parts and look nice. They lower the seat height maybe 30-50 mm and I think they improve the ride as well. Easy to install, but I had to cut the black plastic fender a little on the right side so it wouldn't rub on my YSS shock reservoir.
Johnny
kar120c
Post by kar120c »
montliz44 wrote:I have them on my Forza. They're good parts and look nice. They lower the seat height maybe 30-50 mm and I think they improve the ride as well. Easy to install, but I had to cut the black plastic fender a little on the right side so it wouldn't rub on my YSS shock reservoir.
Johnny
So, no fork tuning necessary? may you post a pic if you can?
montliz44
Year: 2013,2014
Color: red+redder
Post by montliz44 »
I haven't changed my front forks; they seem fine to me. There are several good pictures of the rear shock extenders on the thread called "Hello From Thailand" on page 2 of the Forza/general forum.
Johnny
Dezzie
Post by Dezzie »
Anyone have a link to these brackets for the new forza 300 or do they all fit the same for both years?
SteveP
Post by SteveP »
I just installed them on my 2014 Forza and am happy with hem...the slightly lower seat is nice when having to back up using your feet and the ride may be slightly less jolting. But there is one downside...it's a LOT harder to get the scoot up on the center stand! The stand hits the ground farther back then designed for, causing a loss of leverage. So if you are a light weight weakling like myself (135 lbs ready to ride), be aware of this. I have found that running the rear wheel up onto a 1/2" thick piece of wood first makes it again easy to get on the center stand. These links raise the rear wheel only about 3/8" when scooter on the center stand...rider/scooter weight and spring pre-load setting will change that when it's on it's wheels.
Hi kar120c, here's where member montliz44, Johnny was pointing you to (in case you didn't find it):
https://www.hondapcx.org/viewtopic.php? ... 89&start=0
True that :P this forum's member's rock!
Year: 26 adv 160
I have a pair I bought for my xmax and took them off after a few people from Thailand told me they are seeing these brackets vector the force back instead of down And cracking the case.....There is a real good picture of a failed unit right here on the Advrider site
https://advrider.com/f/threads/new-xmax ... t-36450286
I think a better way to go is a shorter shock.
glencoeman
Post by glencoeman »
kar120c wrote:Anyone has tried these? https://bikerzbits.com/forza-lowering-bracket.html
Due to the design of the front fork, it would be very difficult to lower the forks without spending a lot of money.
SteveP
Post by SteveP »
SteveP wrote:I just installed them on my 2014 Forza and am happy with hem...the slightly lower seat is nice when having to back up using your feet and the ride may be slightly less jolting. But there is one downside...it's a LOT harder to get the scoot up on the center stand! The stand hits the ground farther back then designed for, causing a loss of leverage. So if you are a light weight weakling like myself (135 lbs ready to ride), be aware of this. I have found that running the rear wheel up onto a 1/2" thick piece of wood first makes it again easy to get on the center stand. These links raise the rear wheel only about 3/8" when scooter on the center stand...rider/scooter weight and spring pre-load setting will change that when it's on it's wheels.
Actually the thickness of the wood block is 11/16"
Can’t you cut the fork springs down?
glencoeman
There is not a lot of play in the forks as standard and shortening the fork springs would make it even less with the chance of hitting the front mudguard when braking hard.
True. Try it with added preload (coins) or uprated springs?
davenowherejones
Post by davenowherejones »
My dealer put a bit of plastic pipe in the forks, I guess to increase the preload.
My real problem was that the forks had virtually no oil in them from the factory. It rode really bad with no oil.
Now it works pretty good.
