Special tool to remove drive pulley
Posted: Thu Jul 07, 2016 11:16 pm
by outlander
Tonight I attempted to swap out the rollers but could not undo the drive pulley nut.
The service manual states I need tool 07725-0030000. It's $90. What is the cheaper alternative?
Re: Special tool to remove drive pulley
Posted: Fri Jul 08, 2016 12:11 am
by Alibally
I made one.
Sent by carrier pigeon.
Posted: Fri Jul 08, 2016 12:13 am
by outlander
I saw this but I am really looking for an alternative off thr shelf tool.
Posted: Fri Jul 08, 2016 12:40 am
by kramnala58
outlander wrote:I saw this but I am really looking for an alternative off thr shelf tool.
Check at AutoZone. I think they may even lend tools for free. An alternative might be some of the local rental shops.
Posted: Fri Jul 08, 2016 2:13 am
by flyingzonker
you can get one on Ebay for 9$. It may take a week to get to you--being sent from China--but it should do the trick. When I fool with variator or clutch I use an impact wrench both to loosen and--this is heretical to some-- to tighten again.
Posted: Fri Jul 08, 2016 2:17 am
by flyingzonker
Alibally wrote:
I made one.
What does the author of this mean "buy one from Honda"? Why buy one from Honda when you can get a chinese knock-off for 9 bucks?
Posted: Fri Jul 08, 2016 2:22 am
Search eBay or Amazon for "variator tool", you might also need a tool to hold the clutch drum, I use a large strap wrench.
Posted: Fri Jul 08, 2016 3:23 am
by Oyabun
Posted: Fri Jul 08, 2016 10:47 am
This is what many of us have. Maddiedog has one also.
http://www.amazon.com/gp/product/B000HS ... ge_o06_s00
Posted: Fri Jul 08, 2016 1:26 pm
by flyingzonker
gn2 wrote:Search eBay or Amazon for "variator tool", you might also need a tool to hold the clutch drum, I use a large strap wrench.
Actually you can use the variator holder with the clutch too--stick the pins in the holes of the clutch cover.
Posted: Fri Jul 08, 2016 3:09 pm
True, you can do that but its not very secure, I prefer the strap wrench.
Posted: Fri Jul 08, 2016 8:40 pm
by honkerman
Those are great. That's what a lot of shops use for clutch baskets and such and you can use it on many different clutches.
Posted: Fri Jul 08, 2016 11:59 pm
by outlander
I'd like to go with this.
Posted: Sat Jul 09, 2016 10:54 am
It is a heavy tool but it works and is adjustable like a vise grip.
Posted: Fri Jul 22, 2016 6:15 am
by pxc-in-japan
I got a generic version, variously named as a clutch tool, a pulley holder and variator tool.
In principal they all do a very similar job in a very similar way, and as mine is adjustable, it is suitable for a range of sizes and shapes etc.
it was about 1800 yen (certainly less than 2000), which is about 18-20 USD I think
Amazon Japan has a few varieties (no good to you I know) and that means that regular Amazon will have twice as many. It is often necessary to use it along with a flat wrench (at least on the scoots I have done).
Posted: Tue Jul 26, 2016 11:23 pm
by outlander
The motion pro tool off amazon will not work. I purchased it, the pins on the tool are too wide. Reckon a harbor freighg impact gun will work?
Posted: Wed Jul 27, 2016 5:32 am
by fish
outlander wrote:The motion pro tool off amazon will not work. I purchased it, the pins on the tool are too wide. Reckon a harbor freighg impact gun will work?
A few seconds on a grinder does the trick. Slim them down.....or if not gainfully employed...use a hand file while singing work songs.
Posted: Wed Jul 27, 2016 9:50 am
by outlander
I ended up ordering a cheap Chinese one with two different sizes.
As for the ncy variator. Are the 125s and 150s the same?
One scooter dealer told me its the same part while another told be they are both different.
