Page 1 of 2
compatible wheels?
Posted: Tue Jul 05, 2016 1:27 pm
by superray
Hi all
I'm a bit new to this so please bare with me.
I really love my PCX but really wished the rear rim is wider so I can fit more then a 120 tire in the back. I know someone had fitted 140 and spaced the air box but I feel unsafe to do so on such a narrow stock rim.
So the question is, what other bike has a compatible rim but wider which can be swapped out to the pcx?
I intend to remove the air box and fit a can filter and remove the mid guard and fit an alternative.
Re: compatible wheels?
Posted: Tue Jul 05, 2016 2:00 pm
by superray
Just found out that a Forza is
120/70 - 14 front and
140/70 - 13 rear
Can the Forza rims be fitted to a pcx?
Posted: Tue Jul 05, 2016 4:41 pm
superray wrote:Can the Forza rims be fitted to a pcx?
No.
The wheel on a PCX has a brake drum in the middle of it, a Forza wheel has a brake disc bolted to it.
The two wheels are completely incompatible.
Posted: Tue Jul 05, 2016 5:50 pm
by honkerman
It's generally not a simple matter to simply change out a wheel for a different size. There are several considerations to take into account. As GN2 pointed out, the PCX has a rear drum brake. Along with that, Modifications would need to be made to the rear swing arm as it is currently is set up for a specific hub width.
Personally, I see little point in changing the tire width since there isn't really any major advantage to the wider rubber on such a small machine. Different rubber compounds will have more effect and cost less than going through all the modification headaches needed to add an overwidth tire, and Michelin city grips are flippin' cheap for the quality you get. Of course, if you wish to be like the idiots who ruin their cars by "stancing" them, just to get a certain look, go ahead, it's your money, but you risk destroying a perfectly good scooter for little return in the long run.
Posted: Tue Jul 05, 2016 6:01 pm
by homie
superray wrote: I know someone had fitted 140 and spaced the air box but I feel unsafe to do so on such a narrow stock rim.
Many have already done this mod riding their PCX's thousands of miles with absolutely no reason to feel unsafe, and actually feel much safer than the stock tires/tyres/terrs. It won't be flying off and it won't be going on easily either. We are not on the track at 160 mph with our scooters... you will be fine 8)
Posted: Wed Jul 06, 2016 9:28 am
by superray
Thanks gn2 & homie. I'll give 140 a go then.
Posted: Wed Jul 06, 2016 9:57 am
honkerman wrote:It's generally not a simple matter to simply change out a wheel for a different size. There are several considerations to take into account. As GN2 pointed out, the PCX has a rear drum brake. Along with that, Modifications would need to be made to the rear swing arm as it is currently is set up for a specific hub width.
Ooooh a BRZ. I've got one of those.
Posted: Sat Jul 23, 2016 7:31 am
by St.Clair
I would go to a good tire fitter first with real experience rather than hearsay and a handful of people who have put a 140 and aftermarket air box who really don't want to tell you how weird the tire looks on the rim or the speed they love at through the air box.
A good fitter will use the correct guide to point you in the right direction. speed is not the only thing that can pull the tire off the rim....a big enough pot hole will do the trick. Get the guys with the 140 on the back to show you the profile and angle of the sidewall of the tire and how much it's been pinched in.
Not a good look on standard rim and screams wrong tire.
I would go with a wide 13"s And a tire to make up the height of 14s
Failing that Pirelli front and back.
Posted: Sat Jul 23, 2016 8:01 am
by chicaboo
Stock looking expensive 13" wheels that list max rear tyre size 150/70-13:
http://www.powerbypcx.com/en/accessorie ... v2-v3.html
A few cheap wider 14"wheels:
http://nolimitz-maticshop.com/en/search ... rch=Search
Posted: Sat Jul 23, 2016 8:42 am
by k2apache6.0
And I have city grips new in 140/70-14 rear, and 120/70-14 front, for sale @ $100 the pair if you're in the states
Posted: Sat Jul 23, 2016 9:56 am
by Oyabun
BTW forza 125 wheels just happen to fit the pcx and they are 14 with wide enough to fit a 150 tire at the rear.
Posted: Sat Jul 23, 2016 10:38 am
by St.Clair
chicaboo wrote:Stock looking expensive 13" wheels that list max rear tyre size 150/70-13:
That's a lot of money. Those wheels are £100 elsewhere in Thailand. Even Yoko wheels are only £100 a pair... I see your dilemma. The exporters are charging way too much.
Posted: Sun Jul 24, 2016 4:32 am
by superray
Thanks for the links
Posted: Sun Jul 24, 2016 4:33 am
by superray
k2apache6.0 wrote:And I have city grips new in 140/70-14 rear, and 120/70-14 front, for sale @ $100 the pair if you're in the states
Thanks for the offer but I'm in the UK.
Posted: Sun Jul 24, 2016 4:34 am
by superray
Oyabun wrote:BTW forza 125 wheels just happen to fit the pcx and they are 14 with wide enough to fit a 150 tire at the rear.
You sure?
It was just previously said that they don't? I was thinking changing the rear hub brakes to disk brakes would be a plus side if it has to be done to transfer.
Posted: Sun Jul 24, 2016 5:25 am
by Oyabun
You sure?
100% sure. You have to change a lot of things to convert to rear disc brake though.
Posted: Sun Jul 24, 2016 5:47 am
Any pictures of said conversion to a Forza rear wheel?
It would be massively expensive.
Posted: Sun Jul 24, 2016 5:59 am
by chicaboo
This place sells ugly cheap wider rims:
http://nolimitz-maticshop.com/en/search ... ery=Wheels
Posted: Sun Jul 24, 2016 6:26 am
by Oyabun
gn2 wrote:Any pictures of said conversion to a Forza rear wheel?
No pictures of a said conversion - still waiting to come across an affordable totall loss forza125. However the compatibility was first suspected based on cross refrencing part numbers - and confirmed with a quick check during tire change on a forza. Haven't got enough time to try fitting it and confirm that the drum brake fits immediately, but the wheelnis machined out like it should fit it - so even is the rear disc conversion is highly sought after - not necessary.
Posted: Wed Jul 27, 2016 1:23 am
by superray
Excellent.
There are loads of Forza here in the UK and many bad riders so loads being broken here.
