2013 PCX 150 changing odometer KM to Miles and vice versa
Posted: Tue Jun 28, 2016 11:37 pm
by ScottDR
Hi all,
Is this possible? I did a lot of searching so my apologies if that information is on this site.
Thanks in advance!
Scott
Re: 2013 PCX 150 changing odometer KM to Miles and vice vers
Posted: Wed Jun 29, 2016 10:06 am
On my U.S. model the kph is smaller and is under the mph, which is printed in larger letters. As far as the odometer part in concerned, I don't see how you can change that without changing the entire speedometer.
Posted: Wed Jun 29, 2016 12:31 pm
by Alibally
I don't think you can change it.
Sent by carrier pigeon.
Posted: Wed Jun 29, 2016 2:17 pm
by iceman
Not sure if the US / Canada models follow UK 'E' standard or align to the European models 'ED', but for UK 125's, with average fuel used displayed you press and hold the mode switch for mode than 2 seconds and you can then select between four things - mile/g, mile/l, km/l or l/100km. If km/l or l.100km are selected the trip and odometer show km's if mile/g is selected then they show in miles. May be worth a play?
Posted: Wed Jun 29, 2016 5:40 pm
Who cares. Slow is slow. It's a scooter
Posted: Wed Jun 29, 2016 8:09 pm
by kramnala58
The only way I know how is to swap you present instrument panel out for one like this, which I did.
- PCX Speedometer.jpg (146.02 KiB) Viewed 3711 times
Posted: Wed Jun 29, 2016 9:45 pm
by ScottDR
Ok, thanks all. I figured as much but thought I had seen it on this forum. Maybe what I read was for the Forza (it was late at night, could have been
Thanks again. Hope to make the 12 hour ride to Ohio and back on Friday to title/register it.
Posted: Thu Jun 30, 2016 5:14 am
by dkazzed
I thought the OP was asking about the odometer which is the cumulative distance traveled?
Posted: Thu Jun 30, 2016 7:10 am
by iceman
dkazzed wrote:I thought the OP was asking about the odometer which is the cumulative distance traveled?
They were - which for UK models at least, and from my post, changes from km's to miles if you change the mpg from L to G.
