Coming up to 12 thousand K's
Posted: Mon Mar 28, 2016 11:02 pm
by pcx150man
My 2014/15 150 is coming up to 12 thou k's...anything major to have done here?...I have only been changing the oil(both gearbox and engine) about every two thousand or so...and only ever had the 1st service done at the dealer, and not sure if they did the oil strainer or not...and I have not touched it at all ever!!
fyi...all going well still.
thanks pcx150man
Re: Coming up to 12 thousand K's
Posted: Mon Mar 28, 2016 11:21 pm
by iceman
I believe people mentioned no need to change oil sooner than the recommended interval, but no harm if you do. That said, how have you changed both sets of oil thingies and not had the screen out once? (if I read this above correctly). You should have checked it when you first changed the oil yourself, just to make sure - no need after that as all the crud comes out in the initial use of the bike.
Do you have the owners manual? It has the service schedule and is similar across all age of PCX - try this
http://www.hondampe.com.au/docs/owning_ ... 5_2011.pdf
The belt needs inspecting or changing - it may last a few 1000 miles more.
The spark plug and air filter need inspecting, although only the air filter will need changing as it cannot be cleaned (it's sticky). The spark plug is cheap, about £5 but some have used the same one for a lot longer - if it looks fine and the bike runs fine, maybe stick with it but buy a spare!
Posted: Tue Mar 29, 2016 3:33 am
by pcx150man
iceman wrote:I believe people mentioned no need to change oil sooner than the recommended interval, but no harm if you do. That said, how have you changed both sets of oil thingies and not had the screen out once? (if I read this above correctly). You should have checked it when you first changed the oil yourself, just to make sure - no need after that as all the crud comes out in the initial use of the bike.
Yes, you have that correct, I am hoping it was checked and cleaned in the first service.
Posted: Tue Mar 29, 2016 10:34 am
by montliz44
Good job, PCX150man!
Congrats on your great service record. My PCX only has about half as many Ks as yours does and I have had zero problems with it so far. I have noticed that my belt sometimes acts a little stiff and vibrates somewhat noticeably on takeoff until it warms up, so I'm guessing it's beginning to show its age a little. If it keeps doing that, I'll take the cover off and have a look.
Have you noticed any signs of aging at 12 thousand Ks?
Johnny
Posted: Wed Mar 30, 2016 8:46 am
I am a little confused. A 'K' is a thousand, which means 12K is 12,000.... 12 thousand 'K' is a LOT more miles than 12 thousand (that would be 12,000 x 1,000). I am assuming you meant 12K miles, which isn't really that much on a PCX. My wife's bike has 13K on it right now. We just follow the suggested maintenance on it, though we did change out the belt because the top end was dropping.
Posted: Wed Mar 30, 2016 9:20 am
by iceman
I just took it as 12 thousand kilometer's
Posted: Wed Mar 30, 2016 8:15 pm
by AustinPCX
1k = 1000 meters (or $1000.00 US )
12k = 7.456 US miles
12,000k = 7456 US miles
Posted: Thu Mar 31, 2016 1:17 am
by Robbie
AustinPCX wrote:
1km = 1000 meters
12km = 7.456 miles
12,000km = 7456 miles
FTFY.
K just means 1, 000.
I am going to claim miles as an English unit of measurement you guys use under license
Posted: Fri Apr 01, 2016 5:35 am
by pcx150man
iceman wrote:I just took it as 12 thousand kilometer's
Yep
..........Australia we do kilometres
Posted: Fri Apr 01, 2016 11:20 am
Forgive me. I'm an engineer. 'K' is thousand. 'k' is kilometer.
