Page 1 of 3
Honda vs Givi Accessories
Posted: Tue Sep 11, 2012 9:43 am
by kyle6357
For rear trunks......Honda or Givi (E370). I don't know what you all think on quality, etc. also looking at the windshield too.
Re: Honda vs Givi Accessories
Posted: Tue Sep 11, 2012 11:55 am
by rich666
I'm not sure if it's the same in the US or not, but, in the UK the Honda top boxes are Givi.
Prices can differ by quite a bit between having a "givi" badge or "Honda" badge.
I'd personally say Givi all the way they are quality products.
Posted: Tue Sep 11, 2012 12:05 pm
by kyle6357
Meaning Honda charges more for same product?
Posted: Tue Sep 11, 2012 1:13 pm
by rich666
you got it!. usually about 10-15% more for a badge
Posted: Thu Sep 13, 2012 9:38 am
by maddiedog
It's the same in the USA too -- the mount plates are IDENTICAL. I haven't looked at the Honda version of the topcase (it was too small), but I think it's also a Givi.
Givi makes good stuff, their topcases will last the lifetime of your bike.
Posted: Sat Feb 16, 2013 12:26 pm
by khaosaming
Honda rear rack and a Honda rebadged Givi topbox on a PCX 150 in Trat:
This rack is mostly plastic.
Posted: Sat Feb 16, 2013 1:31 pm
The Honda box and convertor plate are Givi but there are major differences in the Honda/Givi rear rack and how it mounts to the frame.
The Honda one is much neater but here in the UK, hugely more expensive.
Honda bolts direct:
Givi has these ugly brackets:
Posted: Sat Feb 16, 2013 3:18 pm
by khaosaming
There must be at least three different rear racks available. One is from Kivi (with the "ugly brackets"). Honda has a plastic rack that needs an adapter plate (from Kivi; as seen in my post above), and an all metal one that mounts Honda's own topbox directly (no adapter needed). I guess the latter is the same as on the SH line of scooters (such as the SH300).
Posted: Tue Feb 19, 2013 2:12 am
by PCX Commuter
khaosaming wrote:There must be at least three different rear racks available. One is from Kivi (with the "ugly brackets"). Honda has a plastic rack that needs an adapter plate (from Kivi; as seen in my post above), and an all metal one that mounts Honda's own topbox directly (no adapter needed). I guess the latter is the same as on the SH line of scooters (such as the SH300).
Yeah, pretty confusing from Honda. The plastic one they used on the PCX 125 is not nearly as sturdy as the new one for the 150. The box is crazy expensive, though much improved from the old one. I stuck with a combination of the Givi E370 box with the new Honda mount, which is very clean and sturdy. I listed the part number on my Trunk How To, if anyone is interested.
Posted: Tue Feb 19, 2013 3:04 am
by Taz
Here is my rack, <$50 from Wing Yap in Singapore.
iPhone after UK Aprl 2012 098 by
TazPCX, on Flickr
Posted: Tue Feb 19, 2013 10:27 am
by maddiedog
I've seen Givi plastic plates almost identical to the Honda OEM one GN2 posted too. It's all over the board.
For what it's worth, the flimsy plastic construction of ALL of them is why the load limit for a topbox is so small. If the mounting options were like Taz's rack, you could easily put 2 or 3 times that weight on there.
Posted: Tue Feb 19, 2013 5:22 pm
by Taz
Mine is rated for 13kg I believe.
Posted: Tue Feb 19, 2013 5:32 pm
It's not the construction of the box or the rack or the mounts which is the problem, it is the vehicle's own weight limit which I believe is 10kg?
Posted: Tue Feb 19, 2013 8:20 pm
by khaosaming
maddiedog wrote:For what it's worth, the flimsy plastic construction of ALL of them is why the load limit for a topbox is so small. If the mounting options were like Taz's rack, you could easily put 2 or 3 times that weight on there.
I don't think there's anything flimsy about this rack. It looks sturdy enough to support the weight of another smallish passenger temporarily. I nicked the link to these nice pictures from
PCX Commuter's tutorial. I hope he doesn't mind my copyright violation.
Posted: Wed Feb 20, 2013 10:18 am
by maddiedog
khaosaming wrote:I don't think there's anything flimsy about this rack.
Hmm, that one's metal, and looks up to the task of a lot more weight.
I've seen plastic ones like the one GN2 posted, never seen that nice metal one. That must be a new version they released with the PCX150, because the part is valid and linked to the PCX150 if I look that up online. Awesome.
gn2 wrote:It's not the construction of the box or the rack or the mounts which is the problem, it is the vehicle's own weight limit which I believe is 10kg?
It is, but is a pillion 10kg? Handling won't suffer much from more load. The rear wing is substantial and should be capable of holding far more than 10kg if you have a proper mounting plate like the one khaosaming indicated.
Posted: Wed Feb 20, 2013 11:29 am
maddiedog wrote:It is, but is a pillion 10kg? Handling won't suffer much from more load.
It isn't just the weight, its the positioning relative to the CofG.
Posted: Wed Feb 20, 2013 1:13 pm
by maddiedog
I can actually do some calculations and prove this to you (if you want), but unless you're putting well over 30kg in there, it won't affect handling any more than a passenger would. The PCX isn't exactly a wheelie machine.
Posted: Wed Feb 20, 2013 2:05 pm
I'm sure you can do calculations and suchlike but you will never convince me that adding 30kg to the rear rack of a PCX will leave the handling the same as before.
Posted: Wed Feb 20, 2013 2:31 pm
by maddiedog
It won't, but neither will having a passenger, and Honda endorses that.
Posted: Wed Feb 20, 2013 2:53 pm
I would suggest that they endorse it because the handling remains acceptable with a passenger.
Big weights on the racks of lightweight bikes is a proven recipe for thoroughly evil handling.
Honda say 10kg but hey-ho wtf do they know about designing, producing and selling ptw's
