heated grips
Posted: Fri Jan 15, 2016 1:47 pm
by tomalox
Hello!!
do anybody fitted by yourself genuine heated grips in forza 125
Is manual fitting instruction included with grips??
Thanks for any info
Re: heated grips
Posted: Fri Jan 15, 2016 3:26 pm
by Mister Paul
Can I ask why you want to fit the Honda ones? They're ridiculously expensive. I've just had the Oxford Commuters fitted on my Forza. Less than £50, and wire directly onto the battery terminals. They switch off automatically when you turn the engine off.
Re: heated grips
Posted: Fri Jan 15, 2016 4:23 pm
by tomalox
I know I can have Oxford ones. but I can get genuine Honda from
www.kfm-motorraeder.de for 175.50 eur with delivery = £135 which isn't to bad.
In honda uk they costs £295. I have been today to check.
Re: heated grips
Posted: Sun May 15, 2016 1:26 pm
by Baz
I have the genuine heated grips....They were fitted at PDI, so I'm afraid I don't know for a fact whether they come with fitting instructions or not, although if they're available as a retro-fit accessory it's probably safe to assume that they do!
I went for the genuine grips because they just look so neat....The switch is nice and discreet, mounted right next to the left grip, and operated by the left thumb....It all looks beautifully integrated!
However, the grips don't really get that hot, even on maximum (5) setting....On a cold day, if you're wearing gloves thin enough to feel the heat transfer, I don't believe they would keep your pinkies that warm! I chose to use mitts aswell, and this worked very well in the coldest of temperatures, but if I were making the choice again, I'd probably go for Oxford grips, and tolerate the unsightly switch!
Re: heated grips
Posted: Wed May 18, 2016 6:13 am
by dick the den
Got heated grips on my Honda Vision 110, was on there when I brought it,1st time I have heated grips ,much better in the cold.
Re: heated grips
Posted: Mon Sep 18, 2023 12:22 pm
by Mister_Fube
I realise this is an old thread, but I've felt much the same in the past about Oxford grips - positioning the switch for them can often be unsightly, compared to the OEM Honda grips which are beautifully integrated such that you wouldn't notice you had any heated grips. Well happy days! Oxford are now doing several versions (Pro, Adventure, Touring) with a small switch on the grip itself, much like the Honda grips. The difference between the models appears to be simply the knurled grip pattern in the rubber. Still a darn sight cheaper than the Honda ones.
https://www.oxfordproducts.com/motorcyc ... ntegrated/
