Page 1 of 2
Bike running at "2nd gear"?
Posted: Wed Dec 02, 2015 8:10 pm
by FRossi
Hello guys,
I own a PCX150 with 28k km, and by 20k km I've installed the Yuminashi 2015 kit with stock belt.
First my bike would go until 130km/h, but now 8k km later, it would not pass 110km/h. That's the first sign that something is not right, I guess it would be a worn belt, just 8kkm...
But the main problem started a few days ago.
When I stop at traffic signal, the bike goes off very lazy... If it had gears, the best way to describe would be starting at 2nd gear... And when its about to stop to idle, it vibrates a lot...
Anyone knows what it is?
I would guess that the variator is not going back to the most close-ratio gear position... But I have no idea why its happening.
Worn belt?
Worn rollers?
Dust?
Re: Bike running at
Posted: Wed Dec 02, 2015 8:58 pm
Open the casing take the variator out and have a look, you're more likely to find what the fault is by looking in there.
Re: Bike running at
Posted: Thu Dec 03, 2015 2:13 pm
by St.Clair
When you put it all back together did you use the right torque settings for the cvt etc, made sure the belt was seated properly before doing it all up. First port of call..sounds like it's slapping for some reason.
Re: Bike running at "2nd gear"?
Posted: Mon Dec 07, 2015 4:37 pm
by FRossi
Rollers and belt completely destroyed today...
Seems that rollers were mounted somewhat wrong... I don't believe that they could be this shape by just 8k km!
Now I'm trying to imagine a way to remove the clutch for taking of all the "steel cables" of the belt without any special tool...
What about those chips on the variator face?
![Image](http://images.tapatalk-cdn.com/15/12/07/d2167257ad6de2fdad70ebfe042d48b4.jpg)
![Image](http://images.tapatalk-cdn.com/15/12/07/039acf4922875c9a72abe8289897e1c0.jpg)
Posted: Wed Dec 09, 2015 4:38 am
by FRossi
Polished the damaged rollers housing, removed the chips on the variator face, put everything together and now bike is running fine again!
It seems that the idle rpm is higher than normal, is it possible? Maybe I've made any mistake putting the part together and it get this impression by some unbalanced variator rotation?
[img]
http://images.tapatalk-cdn.com/15/12/09 ... c97c72.jpg[/img]
[img]
http://images.tapatalk-cdn.com/15/12/09 ... 6144c1.jpg[/img]
Posted: Sun Feb 14, 2016 6:39 am
by FRossi
Hey, got another broken belt... Just 4k km after the last belt replacement. I'll take the Yuminashi kit out because its impossible to find a reinforced belt here... It will be sad to go back to original PCX after getting used to the CVT kit....
Re: Bike running at
Posted: Sun Feb 14, 2016 9:28 am
Try the NCY variator and the 13 gm rollers. That should boost your speed up just enough to make you happy....probably in the range of 75 mph.
Posted: Sun Feb 14, 2016 2:45 pm
by FRossi
Mel, its almost impossible to find aftermarket parts in south america... That's why I will take the kit out. I can't find a reinforced belt, neither the NCY vario and aftermaket rollers... This Yumi kit I brought from a trip to Thai...
Re: Bike running at
Posted: Sun Feb 14, 2016 11:04 pm
by waspmike
Sounds like he is running a V1 125 belt on a V2 150? So the belt is too short and gets stretched at high speed and....
Sent you a PM.
Posted: Tue Feb 16, 2016 4:24 am
by FRossi
[img]
http://uploads.tapatalk-cdn.com/2016021 ... 6c0433.jpg[/img]
This are the rollers that came out from the bike.
I don't think that this wear is normal in a 4k km roller... One of the rollers has a huge cut in center.
After the belt replacement yesterday, I've noticed that my belt is a little wobbly. When I snap the throttle I can hear the belt hitting the aluminium case. I first thought that the bolt that hold the vario together could be loose, but I've double checked and it seems to be OK!
Re: Bike running at
Posted: Tue Feb 16, 2016 9:33 am
by waspmike
You are using some kind of wacky app that doesn't show pictures here? At least not for me.
Posted: Tue Feb 16, 2016 10:26 am
by Alibally
waspmike wrote:You are using some kind of wacky app that doesn't show pictures here? At least not for me.
I can see them. I'm using tapatalk on my iPad.
Re: Bike running at
Posted: Tue Feb 16, 2016 9:10 pm
by waspmike
Ah I see what is going on. Tapatalk uploads the images to the viewing device. There is no website to view them on. So interestingly Tapatalk stores images but there is no viewing platform, that is the recipient's device. It is like receiving an email with embedded pictures. If I download the pictures now I can see what a mess Rossi's variator is.
Posted: Wed Feb 17, 2016 10:12 am
by FRossi
And do you have any clue of why I'm breaking so many belts and cutting the rollers?
Any special way to mount the vario?
What I usually do:
1 take the vario off...
2 take the clutch off
3 insert the new belt in the clutch pulley, without opening the pulleys...
4 mount the clutch with the belt.
5 mount one face of the vario with the boss
6 insert the belt in the vario side
7 mount the other face of the vario
8 use a spacer and torque the vario and the clutch.
When I snap the throttle, the belt light snap the alu case... Is there any what to tight the belt? Maybe I'm not torquing enough the vario side?
Re: Bike running at
Posted: Thu Feb 18, 2016 2:32 am
by waspmike
^ You don't absolutely have to remove the clutch.
Before tightening the variator nut squeeze the upper and lower lengths of the belt together in the middle to force it down into the clutch. This takes any tension off the belt and prevents you from getting the belt squashed between the pulley halves when you torque the nut.
What is the spacer for? Did the bike originally have a spacer?
Did it come as part of the kit?
Posted: Thu Feb 18, 2016 5:43 am
by FRossi
Dam... Now I don't remember if this spacer is original or not. It's a little thick washer that mounts between the nut and the variator...
Glad to know that the clutch doesn't have to be taken off. Seems impossible to put the belt in that little clearance of pulley and the aluminium case...
Re: Bike running at
Posted: Thu Feb 18, 2016 6:15 am
by iceman
I thought people add a washer to change performance - isn't it what is done to regulate or de-regulate 50cc bikes?
Re: Bike running at
Posted: Thu Feb 18, 2016 3:36 pm
iceman wrote:I thought people add a washer to change performance - isn't it what is done to regulate or de-regulate 50cc bikes?
No
Posted: Thu Feb 18, 2016 4:26 pm
by Alibally
If a spacer is fitted between the boss and the outer front pulley it enables the belt to sit lower in the pulley so give a little better acceleration. There are different widths of shims but it's only 0.3 or 0.5mm approx so not much will do it. It's a bit of trial and error with aftermarket parts really. Somethings work great but it could be a complete disaster.
Re: Bike running at
Posted: Thu Feb 18, 2016 9:53 pm
by waspmike
^ OK maybe language. In English that would be a washer. So just used for assembly and does not change the dimensions of anything.
I only know gaivote and chave inglese.
I used to call the contractors foreman a gaivote as he would make a lot of noise, sh1t on everyone and then leave.
If the variator is properly designed no spacer is needed! This being said if the OEM unit has a spacer fitted some aftermarket variators include this spacer as it has to do with belt alignment. Always read the entire assembly instructions before installing, including the notes!
