Page 3 of 3
Re: more fuel capacity
Posted: Wed May 11, 2016 3:21 pm
by Cosmic_Jumper
We have been "re-engineering" my buddy Hammy's 2014 NSS300 for Iron Butt long distance riding. We added a 2.5 gal Coyote Gear Tour Tank on a 1/4" aluminum plate mounted to the top case mounts. The TT fuel line connects to the main tank vent hose (disconnected from the evap canister). When empty the main tank is filled first then the TT. When running, the TT gradually replenishes the fuel used in the main tank. The entire fuel system (main & TT) works as one closed system and ultimately vents to the atmosphere via the TT vent. We could have run another line from the TT vent down to the evap canister to make it "legit", but...
He claims a range of 300+ miles a 80+ mph.
A Shad top case was reversed and the mount bolted thru the pillion area of the saddle after removing the butt stop. The butt stop holes were plugged using black plastic push in "rivet" used on automobile panels.
He is currently tweaking the variator with various combinations on rollers & sliders to gain better fuel economy (i.e. lower RPMs) at freeway speeds.
All in all, quite a piece of work. Hopefully he or I will post a photo soon.
http://www.coyote-gear.com/
Tim
Posted: Thu May 12, 2016 11:25 am
I think that it is great that you can fit everything so well. Did it come with instructions so that you would know what you needed in order to set it up correctly? There was a thread somewhere on this forum quite a while back in which someone with a PCX wanted to set up an extra tank. Do you think one could be set up above the muffler? I know that a bracket would have to be manufactured but that seems like the only place it could be set up fairly easily. I guess that you would have to level it there but I believe that the upper frame runs under the plastics there. Since the Forza is set up the same as the PCX in this manner, wouldn't it have been easier for you to set yours up there as well? I am just trying to figure out where else the tank could have been fitted. I use my top box all the time, so I wouldn't want to have to move it.
Posted: Thu May 12, 2016 12:07 pm
by Alibally
It'll just be a gravity feed to the standard fuel tank won't it?
Sent from my iPad
Posted: Mon May 16, 2016 10:23 am
by Cosmic_Jumper
Well, as evidenced below, I am completely "challenged" when it comes to posting photos --in spite of coaching by Fearless Leader, Maddiedog. Anyway here are two links to photos of Hammy's Forza 300 "in full battle dress" showing the 2.5 gal Tour Tank and the Shad case mounted to the seat pillion.
The hose which appears (top photo) along the right side beneath the seat is the hydration hose from the camelback which can be seen peeking out from beneath the sheep skin seat cover.
Yes, the Tour Tank (TT) is gravity fed. Again, the TT fuel line is attached to the main tank vent line which was disconnected from the Evap Canister and rerouted along the left side frame where an automotive fuel filter was used to connect the TT and main tank vent lines.
Sorry to say but there were no "instructions" anywhere about How to..." It did take a lot of bodging before we got things right. IIRC this was our 3rd or 4th TT installation, with the previous installations being done on Silverwing 600 scooters for IBA rallies and long distance rides.
I hope this clears up some questions. If anyone would care to take the initiative to post the photo's here in this thread, please do so. I'm waay too confused by all this
Tim
Posted: Mon May 16, 2016 10:48 am
C:\ relates to a file location on your personal computer.
You need to upload (transfer copies) of the pictures from your computer to the forum site or other hosting site and link to that location.
Posted: Mon May 16, 2016 4:07 pm
by Cosmic_Jumper
Thank you both for your suggestion. But you have no idea just how incompetent and/or dick fingered I can be when it comes to tasks like this.
So I suppose that given they are "C:\" locations you all are unable to open those links.
Tim
Posted: Mon May 16, 2016 4:32 pm
Cosmic_Jumper wrote:Thank you both for your suggestion. But you have no idea just how incompetent and/or dick fingered I can be when it comes to tasks like this.
Tim
We do and no we can't
Persevere
Posted: Tue May 17, 2016 9:01 am
C:\ indicates that it is on your personal computer still. What you will need to do first of all is to make sure that the photo is small enough to fit. There are sizing limits for uploaded pictures. Once you have resized it, then make sure you are in the FULL Editor. It will give you additional boxes to use for photo uploading.
1) choose the photo
2) add the file
3) attach file
4) submit
Posted: Tue May 17, 2016 10:39 am
by davenowherejones
Stuck on a small muddy ice ridge
Posted: Tue May 17, 2016 10:42 am
by davenowherejones
My first try at posting pictures at this site. Too much fuel is good until you are on fire.
Posted: Tue May 17, 2016 6:55 pm
Well, you did a good job of posting. I would have to say that the bike is a bit stuck, and Forzas are not light in weight. I am guessing that you got it out. Did you get help or did you have to wrestle it one inch at a time? (Thinking about that hurts my back.)
Posted: Tue May 17, 2016 8:40 pm
by davenowherejones
Mel46 wrote:Well, you did a good job of posting. I would have to say that the bike is a bit stuck, and Forzas are not light in weight. I am guessing that you got it out. Did you get help or did you have to wrestle it one inch at a time? (Thinking about that hurts my back.)
The heat of the engine melted some of the ice and I attacked the rest with a 17 mm open end wrench to make a way through. It was not that bad really. One guy stopped but I had it almost free at that time and his 900 lb big bike was in danger of tipping so I told him to go.
Why is the Forza so heavy?
Posted: Tue May 17, 2016 10:50 pm
davenowherejones wrote:Why is the Forza so heavy?
Its a similar weight as other 300 maxi scooters.
They're heavier because there's more bodywork and more frame.
Posted: Tue May 17, 2016 11:10 pm
by davenowherejones
gn2 wrote:davenowherejones wrote:Why is the Forza so heavy?
It would interesting to see someone like KTM make a scooter. It would probably be about half weight and twice the power, twice the costs.
Posted: Wed May 18, 2016 6:28 am
by chicaboo
davenowherejones wrote:gn2 wrote:davenowherejones wrote:Why is the Forza so heavy?
And overheat.
Posted: Sun May 22, 2016 12:05 pm
by Cosmic_Jumper
Here are links to Hammy's Forza NSS300, "Aurora", as set up for his ride (from Philly) to San Francisco then turning round and leaving Memorial Day on the IBA's inaugural "George A Wyman Memorial Grand Tour" retracing Wyman's 1903 "motor bicycle" ride from SF to NYC. Sorry no actual photos. But I do hope these links will work and help.
Tim
Left side
https://www.dropbox.com/s/65kw5dlglf94q ... 1.jpg?dl=0
Right side
https://www.dropbox.com/s/m1mxjxfaovx06 ... 2.jpg?dl=0
Front
https://www.dropbox.com/s/3smbwauyw61nc ... 2.jpg?dl=0
Lights
https://www.dropbox.com/s/oy34b7gohcv8t ... 6.jpg?dl=0
Instruments
https://www.dropbox.com/s/gnzr5qauo4vgq ... 1.jpg?dl=0
