braking belts
troy
braking belts
Post by troy »
I have a pcx150 !!! I keep braking belts : any ideas on how to fix that problem?
Have malossi vareator with ncy drive face!
j.d.b.
Re: braking belts
Post by j.d.b. »
Gonna need more info than that. What belt, miles on the bike, mileage between belt breakage, etc.
With what you put up so far, I recommend putting the stock parts in and calling it well enough.
Re: braking belts
troy wrote:I have a pcx150 !!! I keep braking belts : any ideas on how to fix that problem?
What belts are you using?
All aftermarket ones are of inferior quality to the standard one.
The guaranteed cure to the problem is to refit all the standard parts.
Alibally
Re: braking belts
Post by Alibally »
It's probably an incompatible mixture of parts or the incorrect parts for the bike.
There are plenty of theads on here as to what works and what doesn't.
Re: braking belts
Alibally wrote:It's probably an incompatible mixture of parts or the incorrect parts for the bike.
Something works?
Alibally
Re: braking belts
Post by Alibally »
Something works?
Allegedly
sendler2112
Year: 2013 PCX150
Re: braking belts
Post by sendler2112 »
Your mix n match pulleys are probably causing out of alignment. Run it on the stand with the cover off to see if the belt looks crooked.
waspmike
Re: braking belts
Post by waspmike »
If using a Malossi belt, they are wider so get pushed further out. With NYC 120mm pulley half you may be rubbing the belt on the casing?
sendler2112
Year: 2013 PCX150
Re: braking belts
If the belt is pushed out too far, it will also be hanging half off the pully. Run it on the stand with the cover off to see.
