Accessories in Thailand - rear shocks
Posted: Fri Jun 12, 2015 2:45 am
by BobS
Installed some YSS shocks - G-Euro offset, XXL rated.
Cost in Thailand - $110 USD
Easy enough to install, EXCEPT that the storage box has to be raised a couple inches to get the top of the shock off or on the bolt. That involves removing the two parts of the grab rail.
- Rear shocks.JPG (144.02 KiB) Viewed 1874 times
Re: Accessories in Thailand - rear shocks
Posted: Fri Jun 12, 2015 6:09 am
by Dustoff66
BobS wrote:Installed some YSS shocks - G-Euro offset, XXL rated.
............. Which involves removing most of the body plastic, a frustrating and time consuming task which shouldn't be done by the novice without a detailed service manual ( which I have ). Too much effort for moi.
Posted: Fri Jun 12, 2015 6:18 am
by BobS
You only have to remove the two parts of the grab rail - the plastic and the metal. Once you do that, you can raise the back end of the storage box enough to get the shock in and out.
