Finally!! 12V socket installed under the seat! DIY!
Posted: Thu Mar 19, 2015 12:03 pm
by coetzee.kruger
Step one of customization 99% done! Complete with switch to prevent the battery from draining...
Just a bit of cosmetic rounding off to do around the socket itself, and then its done!
Re: Finally!! 12V socket installed under the seat! DIY!
Posted: Thu Mar 19, 2015 3:09 pm
by wei2go
Can you still get your helmet in there?
Posted: Thu Mar 19, 2015 9:47 pm
by coetzee.kruger
wei2go wrote:Can you still get your helmet in there?
Havent tried yet. Sure i will be able to if i leave the visor a tad open as the socket is at height, but even If I cant I can still put it in the box on the back.
Posted: Fri Mar 20, 2015 3:34 am
by coetzee.kruger
Just had a look and the helmet still fits in just fine.
Also saw that my front tire was loosing a slight bit of pressure, so pulled out the mini air compressor, plugged it into the new 12V under the seat and quickly inflated it myself
Now she is almost set for the long roads!
Posted: Sat Mar 21, 2015 11:06 am
by tbln930
How do you plug in a battery tender?
Posted: Sat Mar 21, 2015 12:00 pm
by coetzee.kruger
Hmmm battery tender?
Posted: Sat Mar 21, 2015 12:30 pm
Maybe you don't need a battery tender. Hmm
Just a quick connect. Not a bad item to have wired up and available Should You ever need/want to plug in a battery maintainer. A must for me. But then, I don't ride anywhere near as much as others do here. Still, it can't hurt to have one. Hmm...can You now? That was the question
Posted: Sat Mar 28, 2015 11:04 pm
by caseybea
Pretty interesting. I really really want this in my glove box, but that's a lot more work. Your method here has piqued my possible interest. What does the other side of the battery cover look like, can you pull it out and take a photo?
Posted: Sat Mar 28, 2015 11:58 pm
by coetzee.kruger
caseybea wrote:Pretty interesting. I really really want this in my glove box, but that's a lot more work. Your method here has piqued my possible interest. What does the other side of the battery cover look like, can you pull it out and take a photo?
When I am at the bike again I will see what I can do for you
Posted: Sun Mar 29, 2015 11:25 am
caseybea asks: "What does the other side of the battery cover look like......?"
I have a 2015 PCX, I'm pretty sure the 2013 is the same. Here's mine. I also have the battery tender pigtail leads connected to the battery terminals.
Posted: Sun Mar 29, 2015 11:30 am
by coetzee.kruger
I think he meant the wiring. Here is the link to the post just made..
http://www.hondapcx.org/viewtopic.php?f=7&t=4190
Posted: Sun Mar 29, 2015 11:36 am
Alrighty then
But....he got a bonus view of the battery tender pigtail and fuse box. Guess what coetzee?
I don't have a plastic push pin to lose
Honda fixed that! My 2011 had that pushy pin, I broke it the day I added a pigtail to its battery. Now....The 2015 cover just snaps in place, no pin. Thank You Honda!
Posted: Sun Mar 29, 2015 11:37 am
by coetzee.kruger
WhiteNoise wrote:Alrighty then
BRILLIANT WORK MY FRIEND!!
Posted: Sun Mar 29, 2015 6:49 pm
I lost my push pin but had a bag of them from when i owned my Burgman 400. They were smart enough to assemble the entire bike with those instead of tabs and screws. It would take me half as long to disassemble the Burgman as the pcx.
Posted: Mon Mar 30, 2015 10:50 am
Ya'll might be interested at how maddiedog (our forum(s) owner) wired in a socket. Also other ideas found here in the Technical Help Board > "How-To" category:
http://www.hondapcx.org/viewtopic.php?f=3&t=18&start=20
Have Fun!
Posted: Wed Oct 21, 2015 1:32 am
by marcdman4000
Not sure of the other years. But I just picked up a 2016 and it comes with one in the glove box. Also the glove box is HUGE. It fits my Samsung Galaxy Note 5 with a case on it.
Posted: Wed Oct 21, 2015 9:10 am
Welcome marcdman (cool name, I see what you did there
glad to have you aboard the forum(s)! I bet you're lovin' your new toy it's such a pleasurable two wheeler to ride.
About the cubby...You got a Galaxy Note in there? That's good to know! I have an S4 to be upgraded soon, may look at the Note. Yes, the 2015 has a nice size cavity. Right now, I have a 16.9 oz bottle of water and small pepper spray in there. Fits no prob
- image.jpeg (63.75 KiB) Viewed 4890 times
Before I shut my mouth
would you do us All a favor and add your location to your profile?
Oh, no worries...none of us will come to dinner unless we're invited (well, ahem....most of us anyway
Seriously speaking we come from all over the globe and telling us your location really helps in answering any questions you may have (and vice versa). Tis easy to do, you can simply follow my easy directions right below vvv
Thanks dman and Love thy Bike
Posted: Wed Oct 21, 2015 4:21 pm
by fabianfred
I just got my new PCX and like the big glove box...but how do you use the power outlet as most chargers for phones which plug into the cigar lighter in a car are too bulky to fit in the PCX one...
I also use the Note 4
Posted: Wed Oct 21, 2015 7:20 pm
I did a quick Google search and came up with a variety of adaptors. Maybe one will work with your Note?
http://www.google.com/search?biw=360&bi ... UrbAyrbAh8
