12v Power Outlet Question
Posted: Sun Dec 21, 2014 5:21 pm
by SECoda
I need to power at least my smartphone and preferably both my smartphone and camera as I ride. Right now I tape the compartment door shut with a piece of masking tape which works fine but looks a but tacky. Is there a better way?
Re: 12v Power Outlet Question
Posted: Sun Dec 21, 2014 5:40 pm
SECoda wrote:I need to power at least my smartphone and preferably both my smartphone and camera as I ride. Right now I tape the compartment door shut with a piece of masking tape which works fine but looks a but tacky. Is there a better way?
Get a mullet, they look very tacky.
Posted: Sun Dec 21, 2014 7:17 pm
by SECoda
I expected an answer like that but never from you.
Posted: Sun Dec 21, 2014 11:41 pm
Yes.
Place the camera, smartfone and USB cables inside the compartment then close it normally.
Posted: Sun Jun 28, 2015 2:23 pm
by NeilForza
My socket has stopped working, I can't find a blown fuse though.
Mine is a UK model, where is the fuse?
Posted: Sun Jun 28, 2015 2:38 pm
I'll try. I don't own a Forza (pcx here), but I'm thinking you open your seat, open your battery box and lastly open the fuse bin cover. Do you have your owner's manual?
Posted: Sun Jun 28, 2015 3:51 pm
by Atis
It's under the top cover of the dash above the right side box. Open the box to find a couple of screws remove them and pull up the cover. Sorry I don'the remember the fuse location or value.
Posted: Sun Jun 28, 2015 4:45 pm
by JohnL
The fuses are inside the battery compartment, on top of the battery, in the fuse compartment.
Posted: Sun Jun 28, 2015 6:08 pm
by BRed
there are 2 fuse boxes.....
all the heavy stuff for the engine and FI is in the lower fuse box near the battery
all the lights, horn, gauges, accessories, etc..... are under the cover of the right box
if you have ABS there are THREE fuse boxes (well, 2 and a half?)
Posted: Mon Jun 29, 2015 11:30 am
Connect Battery Tender permanent connections to your battery. Then buy the power outlet that plugs into it, run a wire under the seat (I ran mine through the opening between the hinge), and connect your devices to it. If what you want to connect can not fit in the glove box, this is your next best option.
