Need help badly
Posted: Sat Jul 12, 2014 10:06 am
by MagicSeaweed
Ok guys I've screwed the pooch,
Went to change spark plug all going well then just as I had it tight enough go to remove the tool and it all breaks off,
What do I do now, can I attempt to cut the sides and remove with a flat head? Or do I need to bite the bullet and take it to a dealer to take it apart and remove?
Any help would be greatly appreciated
Re: Need help badly
Posted: Sat Jul 12, 2014 10:51 am
by dasshreddar
I would first try a dremel tool cut off wheel and make a slot in the stub(for a flat head screwdriver), and or keep chiseling it out... of course don't go into the threads.
keep the threads lubed!
Re: Need help badly
Posted: Sat Jul 12, 2014 10:59 am
by MagicSeaweed
Got the ceramic out so there is no risk of it falling into engine now, time to work out a removal tool to use?
Re: Need help badly
Posted: Sat Jul 12, 2014 12:25 pm
by MagicSeaweed
Ok going to have a go using this guide as it seems to have worked for a few people,
http://adrielmichaud.com/mr-fixit/how-t ... park-plug/
Re: Need help badly
Posted: Sat Jul 12, 2014 4:28 pm
MagicSeaweed wrote:Ok guys I've screwed the pooch,
Did you do this screwing it in or out?
Re: Need help badly
Posted: Sat Jul 12, 2014 4:54 pm
by MagicSeaweed
In sadly
Re: Need help badly
Posted: Sat Jul 12, 2014 8:43 pm
by pcx man
Unless you cross threaded the plug, it should back out very easy. If the plug is sticking out a bit use what ever you have to grip the edge. Have you tried lubing it with WD-40? It may back out just using your finger.
Re: Need help badly
Posted: Sat Jul 12, 2014 10:17 pm
by Mgalutia88
Try one of the stripped Philips head screw easy outs.
Re: Need help badly
Posted: Sun Jul 13, 2014 3:51 am
by Alibally
I see your in Southampton. Pop along here. It's open today.
http://www.machinemart.co.uk/pages/stor ... outhampton
Re: Need help badly
Posted: Sun Jul 13, 2014 3:54 am
by Alibally
You will need one of these.
They work fine. There is a reverse thread on them. You turn them anticlockwise to screw into the plug so it should come out as long as it's not been cross threaded. I presume the ceramic is out the middle so there is the hole in the middle?
http://www.machinemart.co.uk/shop/produ ... wrench-set
Re: Need help badly
Posted: Sun Jul 13, 2014 4:56 am
by MagicSeaweed
Yes got ceramic out, that's great, actually at Thorpe park today XD, but will get on it tomorrow and update progress
Re: Need help badly
Posted: Sun Jul 13, 2014 6:26 am
by iceman
MagicSeaweed wrote:Yes got ceramic out, that's great, actually at Thorpe park today XD, but will get on it tomorrow and update progress
Wonder if your a member of the rccgb?
http://www.rccgb.co.uk/ (just on the off-chance)
Re: Need help badly
Posted: Mon Jul 14, 2014 9:45 am
by MagicSeaweed
Hi guys,
Update that I solved the problem!
I decided to see if I could get a flat head down the hole and gently twist it out....
- image (5).jpeg (33.14 KiB) Viewed 4957 times
Turns out I could!
Thanks for all the help everyone!
P.s Not part of the Roller-coaster society but looks fun!
Re: Need help badly
Posted: Mon Jul 14, 2014 12:49 pm
by Alibally
Well done. Cheaper than a remover set as well.
Re: Need help badly
Posted: Mon Jul 14, 2014 4:39 pm
Well done. Mustn't have taken too much torque to get it out. So presumably the same to get it in
Bit worrying if the plugs are this weak
Re: Need help badly
Posted: Mon Jul 14, 2014 4:59 pm
by DAB
In 40 years of motorcycling this is only the second time I have heard of this happening. The first one was 2 months ago on a VFR 750.
Re: Need help badly
Posted: Tue Jul 15, 2014 6:33 am
by MagicSeaweed
I thought the same about the strength of the plugs as when it broke it was tightened to spec in the owners manual, thus I didn't consider straight away to just try a flat head, but unscrewing was almost frightingly easy aha XD
